Arduino IDE libraries
Started by microblades, October 29, 2016, 09:05:07 PM
microblades
I've downloaded the library from here: https://github.com/LowPowerLab/WirelessProgramming
I'm getting an error when installing the library in the Arduino IDE 1.6.12
"Specified folder/zip file does not contain a valid library"
Any ideas? I've installed several other Motieno related libraries without issue.
Thanks!!
sparky
#1
microblades,
If you browse to the arduino\libraries folder you will see that when you unzipped the WirelessProgramming file it installed it in a WirelessProgramming-master folder.  Opening this folder you will see a WirelessHEX and WirelessHEX69 folder.  Drag these folders into the arduino\libraries folder and then everything will work.
Hope this makes sense,
-sparky
microblades
Yes! That seemed to have done the trick. Thank you!
