I'm experiencing the same proble than charlieroot & Big Country, executing "sudo node chat.js" : <<TypeError: Object #<Server> has no method 'configure'>>
charlieroot, it seems that you managed to get around this ? Could you please explain better how you did it ? I tried to comment out the problematic lines, but they are many ! I have to comment the block of lines 9-18. Now when I run node chat.js, I don't have errors, but when I browse the page "MYADDRESS/chat.html", I only get the text "USERS" and an input field with the send button, but nothing works.
I tried to change the line <script src="socket.io.js"> with <script src="/socket.io/socket.io.js"> as you said in a following post. I got a popup in my browser asking "What's your name ?", but nothing did work either.
Felix, you suggested this could be linked to the suppression of the configure method in this version of node ? In fact, I installed node and npm exactly the way proposed in the tutorial, but the version of both are LOWER than shown in the tuto :
sudo wget
http://nodejs.org/dist/v0.10.12/node-v0.10.12-linux-arm-pi.tar.gznode -v -> 0.10.0 instead of 0.10.12
npm -v -> 1.2.14 instead of 1.2.32
However, thank for the help ...
NB
