Node Power Level
Started by Kilo95, December 19, 2017, 01:10:31 PM
Kilo95
is there a way to have the transmit power level of the nodes reported to the gateway? I've got one node ~175 feet from the house and it shows RSSI between -89 and -100. I have ATC enabled but would like to see what the output power is. It'd be fun if it showed up like the RSSI on the gateway page.
Sure, just send a new metric, and define it in metrics.js.
The transmit level is in RFM69_ATC._transmitLevel.
It was something I was thinking to add, so you can compare the transmit level vs RSSI.
Kilo95
if you were thinking of it adding it, i'll probably just wait til you get around to it.
Should be very simple:
TXLV : { name:'TXLV', regexp:/\bTXLV\:(-?\d+)\b/i, value:'', duplicateInterval:3600, unit:'', pin:0, graph:1, graphValSuffix:'TXLV', graphOptions:{ legendLbl:'TXLevel', lines: { lineWidth:1 } }},
Then just read the level and send it as a new token:
TXLVL:value (should be 0 to 31).
Kilo95
i will give that a try. thanks
Kilo95
so, would it be as simple as placing:
DEBUG("   [TXLVL:");DEBUG(RFM69_ATC._transmitLevel);DEBUG("]");
right after this:
DEBUG("   [RX_RSSI:");DEBUG(radio.RSSI);DEBUG("]");
DEBUG is for ... serial DEBUGging.
Your transmitting node needs to send that metric.
And all metrics (except the special RSSI) should be nam:value without [] or any other characters.
LukaQ
#7
Quote from: Felix on December 19, 2017, 03:27:26 PM
TXLVL:25
in weather node
sprintf(buffer, "BAT:%sv F:%s H:%s P:%s", BATstr, Fstr, Hstr, Pstr);
    sendLen = strlen(buffer);
    radio.sendWithRetry(GATEWAYID, buffer, sendLen, 1); //retry one time
in variable buffer you put BAT:5.02v F:53.2 H:72.4 P:28.5
then you calculate what is the length of buffer
then you send to gateway, BAT:5.02v F:53.2 H:72.4 P:28.5, and length of this buffer
On gateway itself (PI) you need to "teach it" to understand what to do with "TXLV" and you do this with
TXLV : { name:'TXLVL', regexp:/\bTXLVL\:(-?\d+)\b/i, value:'', duplicateInterval:3600, unit:'', pin:0, graph:1, graphValSuffix:'TXLV', graphOptions:{ legendLbl:'TXLevel', lines: { lineWidth:1 } }},
in userMetrics/_example.js
AND NOTE THIS: you need to send TXLV or TXLVL
It has to be one or the other (the same) on PI gateway and what is node sending
Kilo95
so all i need to change on the weathershield node is:
?? then change the metrics.js. I think I could have fumbled my way through the metrics.js work but the node would have given me trouble
Kilo95
or is this correct?
sprintf(buffer, "BAT:%sv F:%s H:%s P:%s TXLVL:%s", BATstr, Fstr, Hstr, Pstr, TXLVLstr);
Kilo95, your last piece of code should work.
You can always try it right away too ;)
You could do this...
    sendlen = sprintf(buffer, "BAT:%sv F:%s H:%s P:%s TXLVL:%s", BATstr, Fstr, Hstr, Pstr, TXLVLstr);
Kilo95
Quote from: Felix on December 20, 2017, 10:38:48 AM
lol. you are correct. i am at work though and won't be home until tomorrow. that's why i replied with what I hoped would work. i'll try it the next day or so. i can remote in and at least do the metrics.js file
thanks to tom too. gives me a couple of ideas to try out!
ssmall
Or this...
    sendlen = sprintf(buffer, "BAT:%sv F:%s H:%s P:%s TXLVL:%i", BATstr, Fstr, Hstr, Pstr, RFM69_ATC._transmitLevel);
On a second thought, keeping tokens as short as possible would be preferred.
So maybe a shorter metric name TXP:value rather than TXLVL? Could even be 1 letter or character (unque from other metrics) but that's less human readable.
Whatever works though..
