Node Power Level
Started by Kilo95, December 19, 2017, 01:10:31 PM
LukaQ
will this be universal for all in next build?
If so, TXP sounds ok so does TXL, short and also human readable
Kilo95
I'll try it the other way since I have it setup already on my gateway. If it doesn't work well, I'll try shortening the name. Thanks for the thought
TXP would imply power, ie dBs, which is not the case. It's just a range of levels which translate to different dBs depending if it's a W/CW or HW/HCW.
I would keep TXL. The metric description/legend can elaborate.
Either way it's customizable if one really wants that, this is just my own preference.
Kilo95
is there a chart somewhere with the conversions for TXL to dbm? i vaguely remember seeing it somewhere. i'll have some time this next week to work on fixing the code for the nodes. i was able to remote into my RPi the other day to fix the metrics.js. i'll update when i get it done
Kilo95
I tried the last piece of code I suggested but when I compile it says it's not declared. I assume that means I need to tie it to rfm69atc file. How do I do that?
What's not declared?
#import <RFM69ATC.h>
