TPL5110 Timer: Avoiding the forced 50ms power interrupt if no DONE signal
Started by arf, July 28, 2021, 11:29:41 PM
arf
Reading the TPL5110 datasheet, it says that power will be interrupted for the last 50ms of the cycle if no DONE signal is received.  I am trying to do low power listen about once per second and if I hear a signal then I am going to take an action for longer than one second.  Thus, I need a way to delay or avoid or otherwise get around that 50ms power interruption.  Any ideas?
It is similar to this Texas Instruments thread, but I am not sure how what an RC circuit is.  It seems like its a capacitor that provides power to bridge that 50ms gap, but wouldn't that mean that power is still delivered to the system for 50ms even when the DONE signal is sent?
Uncle Buzz
This is a late reply, but if it's not solved or if someone else facing same issue, you could consider to use TPL5010 instead of the TPL5110. The TPL5010 is a watchdog who won't cut off your power, it will only send a wakeup signal to wake up your
arf
Thanks Buzz. The issue is that the rest of the system is not made for low power sleeping, so I was trying to hard cut the power.  Another problem I ran into was that the boot time for the rest of the system (M0) was quite long and that messed up my duty cycle ratios.
