RFM69W 915 mHz availability
Started by jordanmills, July 09, 2016, 10:53:18 PM
jordanmills
Looks like the only RFM69W modules available to order are 433 mHz.  Are more 915 MHz modules expected in?
Yes, I have those on backorder, seems like there's a factory bottleneck on those. I don't know when they might come in. At the mercy of Hope.
jordanmills
Quote from: Felix on July 11, 2016, 08:23:24 AM
Stink.  Thanks for the update.  I will sit tight and wait for Hope to get them out to you.
Still waiting for updates as well...
Back in stock now, thanks for the patience.
jordanmills
Quote from: Felix on July 28, 2016, 03:34:23 PM
Awesome, thanks for the updates!  Placing an order shortly.
So... have you considered making/selling a breakout board for 0.1" spacing for these?  Sparkfun has them, but they are for the "C" form factor.
Breakout?
I don't know, maybe. Too busy with other new products right now though, trying to get them published. But I have some ideas cooking in my brain. Just takes time...
The C is advantageous because it's pin compatible with the LoRa radios. So adafruit and SF are using those to avoid having to deal with so many parts. I support lots more radios because I don't have a  million products and I am focused on Moteino and kits around them, plus people like having choices ;)
jordanmills
Quote from: Felix on August 01, 2016, 08:16:32 AM
Breakout?
Maybe I should have stuck with the Cs...
jordanmills
Breakout?
Wait a second... it looks like the RFM69HCW is pin- (or layout-) compatible with LoRa boards, but the RFM69CW isn't.  So a single pad layout can support RFM69HCW and RFM96/RFM95, but not RFM69WW (or RFM69W)... right?
Quote from: jordanmills on August 08, 2016, 11:29:35 AM
So a single pad layout can support RFM69HCW and RFM96/RFM95, but not RFM69HW (or RFM69W)... right?
Right.
jordanmills
Quote from: Felix on August 08, 2016, 12:29:27 PM
Right.
Figured that out the hard way with eagle today.  Lol at me.  Any way, this is a sophomoric effort, but I laid it out a limited (no DIO1-5) breakout for RFM69W and RFM69HCW/LoRa and I'm getting a prototype run done.  It was a LOT uglier when I tried to have pads for RFM69CW and break out all the pins.  I probably need to do more work on the antenna and ground too.  Opinions welcome, feel free to use it if you like.
