Where to get low profile female header sockets?
Started by gregcope, April 28, 2018, 10:44:30 AM
gregcope
Hi
Does anyone have a source, or part number for low profile female pcb sockets. 2.54mm pitch.
The ones i have are 8mm high, when I have seen some that are around half this height.
I need 14 pins or more.
Ideally UK, or cheap shipping to the UK.  I found some on RS, however they were $4 each...
I only need a few.  Massive minimum order numbers not helpful.
Anyone any ideas?
sparky
I don't know that they make them any lower.. the male pins would also have to be shorter.  How about machine headers;
https://www.ebay.com/itm/1x40P-40-Pin-2-54mm-Single-Row-Header-Swiss-Round-Machined-Pins-5-Pcs-/301631251864
gregcope
:-). Thanks Sparky.
Tried those.  They do not fit my IC or other board.  The do not take square male pins.
sparky
#3
You happen to know the height your looking for?
Possibly this one;
https://www.gradconn.com/Files/Drawings/BB02-JT.pdf
gregcope
gregcope
Yes sparky that would probably work!
Any ideas where i can order some for uk delivery at reasonable cost?
Charly86
They are really hard to source, I only found 1 vendor on ebay, but they are fine, only in 40pin, but it's easy to cut
https://www.ebay.com/itm/182205504972
gregcope
Charly86
You're welcome
If you know how to source the corresponding male headers, I'll take it  :D
gregcope
Good idea.  tried those.  The force to get normal pins into those is fierce.
But as I can control the male end on one project, this gives me an idea!
thanks
mhzpower
Check out adafruit. Search for short female header. They are 5mm vs 8mm.
