Hardware support => General topics => Topic started by: gregcope on April 28, 2018, 10:44:30 AM
Title: Where to get low profile female header sockets?
Post by: gregcope on April 28, 2018, 10:44:30 AM
Hi
Does anyone have a source, or part number for low profile female pcb sockets. 2.54mm pitch.
The ones i have are 8mm high, when I have seen some that are around half this height.
I need 14 pins or more.
Ideally UK, or cheap shipping to the UK.  I found some on RS, however they were $4 each...
I only need a few.  Massive minimum order numbers not helpful.
Anyone any ideas?
Title: Re: Where to get low profile female header sockets?
Post by: sparky on April 28, 2018, 10:48:35 AM
I don't know that they make them any lower.. the male pins would also have to be shorter.  How about machine headers;
https://www.ebay.com/itm/1x40P-40-Pin-2-54mm-Single-Row-Header-Swiss-Round-Machined-Pins-5-Pcs-/301631251864
Post by: gregcope on April 28, 2018, 11:43:59 AM
:-). Thanks Sparky.
Tried those.  They do not fit my IC or other board.  The do not take square male pins.
Post by: sparky on April 28, 2018, 12:00:27 PM
You happen to know the height your looking for?
Possibly this one;
https://www.gradconn.com/Files/Drawings/BB02-JT.pdf
Post by: gregcope on April 28, 2018, 01:48:34 PM
Sprry. Height about 4mm would be nice.
Post by: gregcope on April 28, 2018, 01:57:36 PM
Yes sparky that would probably work!
Any ideas where i can order some for uk delivery at reasonable cost?
Post by: Charly86 on June 04, 2018, 01:04:51 PM
They are really hard to source, I only found 1 vendor on ebay, but they are fine, only in 40pin, but it's easy to cut
https://www.ebay.com/itm/182205504972 (https://www.ebay.com/itm/182205504972)
Post by: gregcope on June 04, 2018, 01:09:09 PM
Thanks. 5mm height looks good
Post by: Charly86 on June 04, 2018, 01:13:05 PM
You're welcome
If you know how to source the corresponding male headers, I'll take it  :D
Post by: perky on June 04, 2018, 04:09:13 PM
Would turned pin do?
https://www.rapidonline.com/bkl-10120836-1-x-40-pin-header-overall-height-3-0-mm-2-54mm-pitch-3a-gold-plated-50-8121
https://www.rapidonline.com/truconnect-20-way-turned-pin-sil-header-22-1704
Post by: gregcope on June 04, 2018, 04:57:03 PM
Good idea.  tried those.  The force to get normal pins into those is fierce.
But as I can control the male end on one project, this gives me an idea!
thanks
Post by: mhzpower on July 15, 2018, 02:04:35 PM
Check out adafruit. Search for short female header. They are 5mm vs 8mm.
