OTA (2nd) attemp failed
Started by sparky, July 09, 2017, 02:41:43 PM
sparky
I now have a dedicated Moteino as an OTA programmer but I'm still unsuccessful.  After many attempts I decided to take 2 Moteino's and load them with the Programmer and Target sketches located on Felix's Github page; https://github.com/LowPowerLab/RFM69/tree/master/Examples/WirelessProgramming_OTA with no luck.  Below are the errors I'm getting.  Any help would be greatly appreciated..  Thanks
Edit: Radios being used are RFM69HW so I didn't have to change anything in Felix's example sketches.
sparky,
Sorry for the late reply, everything should work as long as all the required parts/code and settings are in place.
Make sure you got the 4mbit on the target and match the RF settings and the target ID.
The target should be actively listening (RX mode) and have the checkforwirelesshex() call after receiveDone() returns true.
Make sure you are using RFM69_OTA and the latest library sources.
The messages in the first screenshot suggests the com port takes too long to reset the board before attempting to talk to it.
The second GUI suggests the target is not responding.
Not sure what else to suggest at this point.
sparky
#2
Thanks for the reply..
I was expecting your target and programmer examples to work "out of the box"  Other than network ID, Frequency, or node ID that is
The 4mbit was not changed in your example;
// flash(SPI_CS, MANUFACTURER_ID)
// SPI_CS          - CS pin attached to SPI flash chip (8 in case of Moteino)
// MANUFACTURER_ID - OPTIONAL, 0x1F44 for adesto(ex atmel) 4mbit flash
//                             0xEF30 for windbond 4mbit flash
//                             0xEF40 for windbond 16/64mbit flash
SPIFlash flash(FLASH_SS, 0xEF30); //EF30 for windbond 4mbit flash
As mentioned in the OP, nothing was changed from your example sketches.
sparky
#3
Felix,
I found the issue and it works like a charm!
I don't know how many times I looked over the sketch and never thought anything was wrong with the following line;
#define FREQUENCY_EXACT 916000000
After it was changed it worked GREAT!  I guess it was so close to what it should have been that I didn't catch it.
Thanks for your input, again!  :)
Doh, I missed adding that line in the target as well!
Nobody else had an issue though so I never had a chance to change this.
I just added the line in the target sketch.
Thanks for the follow up, glad you have it working.
sparky
The only way I can get this to work is changing;
#define FREQUENCY_EXACT 916000000 to #define FREQUENCY_EXACT 915000000
Leaving it at 916 I keep getting the same errors as posted above.
Nothing else was changed and I'm using the latest library's
Both the units have to work on the same frequency.
The FREQUENCY_EXACT is used to set the frequency to something specific other than the default 433/915 etc.
sparky
Yes, I understand..
What I'm saying is setting the programmer and the target node to;
and under void setup() I entered;
#ifdef FREQUENCY_EXACT
  radio.setFrequency(FREQUENCY_EXACT); //set frequency to some custom frequency
#endif
I get the errors attached below.
I then change the programmer to #define FREQUENCY_EXACT 915000000
and on the target I comment out both;
//#define FREQUENCY_EXACT 916000000 and;
//#ifdef FREQUENCY_EXACT
//  radio.setFrequency(FREQUENCY_EXACT); //set frequency to some custom frequency
//#endif
and it works great
Any tips or suggestions would be appreciated!
Edit: I also tried #define FREQUENCY_EXACT 917000000 with no luck.
Just tried this again, and worked in first attempt, both with the .py script and without.
sparky
#9
Felix,
I never doubted you could get it to work..  The issue is I can't with the default settings in your examples.  Thought I could get some tips/suggestions as mentioned above as to what I might be doing wrong or possibly too high/low RSSI signal or whatever else might cause it not to work.  Apparently not.  thanks
I could think of too many reasons why it would not work. Usually the simple checklist of settings solves the problem, and I think you already did that but ... its very strange that both work at 915mhz and stop working when set to 916mhz, makes no sense, something else must be set somewhere that causes this.
It's usually something very simple that is overlooked. Please check everything hardware and firmware wise and try again.
sparky
Reading another thread I read that this statement CheckForWirelessHEX(radio, flash, false); should be true but in the target sketch you have false as shown above.  What should it be, true or false?
Here is the thread where I read it:
https://lowpowerlab.com/forum/wireless-programming-(aka-ota)/can't-get-ota-aka-wireless-programming-to-work/msg18137/#msg18137
That's the debug parameter, puts out verbose serial output when true, useful when debugging the OTA library.
I would use false in a real sketch.
sparky
Ok, thanks
My nodes RSSI range from 45 - 70
Good, that's a very strong signal.
