How to: OTA (OverTheAir) flash/program, modify bootloader
Started by LukaQ, October 31, 2017, 02:10:19 AM
LukaQ
OTA WILL NOT WORK(for now) FOR NODEs THAT ARE GOING TO SLEEP, to save battery
There are few steps you need to take, before you can start.
This is the hardware and software (I have) you will need:
PICKit2 (can be clone)
WinAVR (https://sourceforge.net/projects/winavr/files/WinAVR/20100110/WinAVR-20100110-install.exe/download)
AVRDUDESS (http://blog.zakkemble.co.uk/avrdudess-a-gui-for-avrdude/), download >>>  http://blog.zakkemble.co.uk/download/setup-AVRDUDESS-2.4.exe
Try without this step first, I don't have libusb0.dll next to avrdude.exe. If AVRDUDESS works, you can skip this step, since you are doing with this program only (It's been so long, can't remember what is bare minimum)
AVRDUDE requires LibUSB (https://sourceforge.net/projects/libusb-win32/files/libusb-win32-releases/1.2.6.0/libusb-win32-bin-1.2.6.0.zip/download?use_mirror=netix)
LibUSB should really be installed the normal way as a driver for a LibUSB device, but if you don't have any such devices then you will need to download this.
Extract libusb-win32-bin-1.2.6.0/bin/x86/libusb_x86.dll to where you have avrdude.exe placed and rename libusb_x86.dll to libusb0.dll
You connect PICKIT2 to 5v arduino (maybe this works if you have level shifters for 3.3v version), which means you MUST NOT HAVE any external flash and RFM69 (or similar) connected, since they are 3.6v max devices, and pickit2 signals are probably 5v.
SLIKA p2avr
Easy table is :
PICKit2: 1 2 3 4 5 6
Arduino:RSTVDDGND121311
Open AVRDUDESS:
-select programmer = microchip's pickit2 programmer
-port = usb
Press detect on the right and it should give you atmega328p
Read fuses and set them to LO:DE HI:DC EXT:FD and write them, read them and you will see fuses will be changed to new (ext might be 0x05, but that is ok, LO and HI will have to be what you set them at)
Under Flash section, you will select your new changed (moteino) bootloader, or moteino bootloader.
Make new bootloader or use existing one for moteino:
Download it from Felix (https://github.com/LowPowerLab/DualOptiboot) and unpack it somewhere. Apart from files inside, you will also need to copy over boot.h and stk500.h (arduino-1.8.2\hardware\arduino\avr\bootloaders\optiboot\)
I did rename the folder to where you now have everything from DualOptiboot-master to DualOptiboot_modded so that I know my bootloader is in there, not original or the one from Felix.
Modding bootloader: (this can be skipped if you only want to turn your arduino from ebay to moteino, for that your bootloader is already made(DualOptiboot_V5.0_atmega328_BlinkD9.hex is one of them))
Here is what I did, and what you need to do for your setup is up to you!
I had different external flash, which means not only it has different ID, it's commands (from datasheet) were not all the same.
My m25p40 has amost everything the same, just one command was a problem.
Moteino bootloader has this commands in
#define SPIFLASH_STATUSWRITE      0x01        // write status register
#define SPIFLASH_STATUSREAD       0x05        // read status register
#define SPIFLASH_WRITEENABLE      0x06        // write enable
#define SPIFLASH_ARRAYREADLOWFREQ 0x03        // read array (low frequency)
#define SPIFLASH_BLOCKERASE_32K   0x52        // erase one 32K block of flash memory
#define SPIFLASH_BLOCKERASE_64K   0xD8        // erase one 32K block of flash memory
#define SPIFLASH_JEDECID          0x9F        // read JEDEC ID
And for my flash I needed to change to
#define SPIFLASH_BLOCKERASE_32K   0xD8        // erase one 32K block of flash memory
Only one line of code changed (maybe I didn't even need to do this, but hey...if you can...right?)
Now you go and make .hex from this.
Open windows START and type cmd, right click on it and run as administrator
use "cd" to change folder to your DualOptiboot_modded folder, where you have files for this new bootloader
type dir to check that you are in right folder
type make atmega328 and your .hex will be created in this folder
Congrats, you have your new bootloader.
In AVRDUDESS, under flash, click browse and locate your new bootloader. Now you are ready to upload.
Press program! and wait few seconds, you should get (  )
Open arduino IDE:
go to File > preferences and under Additional Boards Manager URLs add this:
if you already have something there add , and https://lowpowerlab.github.io/MoteinoCore/package_LowPowerLab_index.json
if it is empty,then just https://lowpowerlab.github.io/MoteinoCore/package_LowPowerLab_index.json
Since you have now original or modded moteino bootloader, you will have to change your board to moteino under tools > board (search for moteino and select it)
You are now at this point as you would have normal arduino pro mini, nano or any other, you can run any code as you did before new bootloader. (REMEMBER!!: if you have now your new moteinos and old arduinos, which look the same from outside, but inside they have different bootloader and if you select wrong board for bootloader that it is inside, you would be able to upload from IDE, you will get error, check that first)
Now for the last and best part:
Send sketch OTA:
open programmer and target from File>Examples>RFM69>WirelessProgramming_OTA
Upload programmer to:
1: normal arduino, don't need flash, just RFM69 (always on 3.3v!!!!!!)
2: your new moteino or bought one
Upload from PC, only for the first time to your moteino with flash,RFM69
-change in target.ino few things:
- #define NODEID      11 (or anything your would like to have this node ID)
- SPIFlash flash(FLASH_SS, 0x2020); //EF30 for windbond 4mbit flash (original mote has flash ID with ED30, you find this from flash datasheet, for my it is 2020, yours might be different again)
- CheckForWirelessHEX(radio, flash, true);
And
// Real sketch code here, let's blink the onboard LED
      Serial.println("Led");
      delay(100);
Upload from IDE (make sure you know which COM is for programmer and which is for target if you have them plug in at the same time to your PC)
in IDE file > preferences, turn on Show verbose output durring: compilation
This will show you, where your sketch hex is stored for Moteino Wireless "OTA" programmer, which is located where programmer and target sketches are
RFM69\Examples\WirelessProgramming_OTA (https://lowpowerlab.com/2017/05/26/wireless-programming-updates/)
Open program
Select COM of your programmer arduino(moteino)
enter target node ID (11) which you used when you uploaded target from IDE for the first time
Browse for .hex file of your new sketch
new sketch will be the same in this case example at was target, just change Serial.println("Led"); to let say Serial.println("New Led");
(Note, if you change ID, #define NODEID      11, to different number and upload OTA, next time that node will have that new number already and 11 won't work from moteino OTA program, you will need to change there too)
in IDE don't press UPLOAD, but Verify, button next to it
Under sketch you will see some text go past by. After done compiling, scroll up a bit and find something, that will say similar to this:
"C:\Users\x\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.4-arduino2/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\x~1\AppData\Local\Temp\arduino_build_128898/Target.ino.elf" "C:\Users\x~1\AppData\Local\Temp\arduino_build_128898/Target.ino.hex"
Sketch uses 14340 bytes (45%) of program storage space. Maximum is 31744 bytes.
Global variables use 721 bytes (35%) of dynamic memory, leaving 1327 bytes for local variables. Maximum is 2048 bytes.
Bingo, AppData\Local\Temp\arduino_build_128898/Target.ino.hex is your .hex to upload.
So select this hex file in moteino OTA program and click green button Start!
you should get a lot of text
Available serial ports found: COM1, COM5, COM11
Opening COM11 @ 115200baud ...
SET TARGET: TO:125
Moteino: [TO:125:OK]
TARGET SET OK
FLX?
FLX?
Moteino: [FLX?OK]
HANDSHAKE OK!.....
Moteino: FLX:299:OK
Sometimes also the time it took to complite.
Moteino: [FLX?OK]
EOF
SUCCESS! (time elapsed: 10.99s)
Moteino: FLX:302:OK
And that's it, if you check your target serial, you should see now, target ID of 11 and New Led being printed
Last file is original arduino bootloader, in name you see what fuses were set, if you ever want to go back to stock arduino bootloader
I still can't believe how far tech has come, PIC can program AVR, to program your IC's you don't even need cables... Almost to good to be true, yet it is and works
Ah, I finally found someplace where I can use my old PICKIT 2!  Sort of... assuming I don't have any low voltage devices, which you would if you have an RFM69.  I guess your flash is 5V tolerant.
This is a good tutorial, but the subject line is a bit misleading.  The purpose seems to be more about changing the bootloader and wireless hex code to work with a different flash chip.  This is useful, but not immediately clear.
I found the AVRDUDESS info interesting, hadn't heard of that before, but I am still struggling with the subject line.
Good work on the tutorial.
LukaQ
Quote from: TomWS on October 31, 2017, 10:35:54 AM
Same here. For changing bootloader, I only had atmega. I didn't search, but could you do this, if you would limit all the lines of Pickit2 to 3.3v?
It is? It was just my path, you could use parts of this for just about anything, perhaps only to upload bootloader to new atmega or if you can't get the same flash ship anymore. I think title is valid because of this. Anyway, if you read whole post, it can't hurt to know, maybe you see something new
Anything I can help with?
Thank you
