Author Topic: Small loop antennas @ 433 Mhz  (Read 330144 times)
Re: Small loop antennas @ 433 Mhz
« Reply #15 on: May 30, 2016, 09:37:00 AM »
I assume you use this with your own tiny nodes? Did you try this on a Moteino?
This was actually on my esp8266/rfm69hcw gateway. I haven't tried with Moteino's yet. On my tiny nodes I'm not considering dipoles for reasons that should be obvious from the picture  ;)
« Reply #16 on: May 30, 2016, 10:03:46 AM »
I thought maybe you are using it for buried nodes or a gateway node. But perhaps I totally forgot you are using a esp gateway.
« Reply #17 on: May 30, 2016, 10:11:03 AM »
Buried nodes are special because the changing moisture content of the soil causes wavelength to change very drastically. So an underground antenna needs to be very wide-band. I have a couple of ideas there but nothing actually tried out yet.
But yeah, I think for the gateway dipoles are a great option. Having a big and efficient antenna at the gateway gives you more room to compromise on space or otherwise constrained motes.
john4444
  • Jr. Member
« Reply #18 on: May 30, 2016, 02:58:45 PM »
Hi Joe, My Moteinos are all in the 915-Mhz band. I investigated loop antennas but quickly got discouraged because of the small physical size and measurement accuracy needed to construct the antenna. In addition, I suspected that the tiny capacitance value required to tune the antenna would be very difficult to maintain since it is sensitive to objects in the local environment.
However, your experience at 433-Mhz is causing me to re-examine the issue.
I suspect it may be feasible to isolate the tuning cap is such a way that the loop its self could be sealed against moisture. If this idea works as expected, then buried Moteinos would be able to provide normal range and signal level using magnetic loop antennas.
I'm going to need some 433-Mhz Moteinos just so I can play around with them.
John AE5HQ
captcha
  • Full Member
  • Country: au
« Reply #19 on: May 30, 2016, 06:03:56 PM »
Great to read you're seeing such an improvement.
Speaking from an antenna perspective we (or certainly I) have really been living in the stone age.
Looks like the VNA has opened your eyes..  :)
What length and type of feedline are you using?
« Reply #20 on: May 31, 2016, 02:16:16 AM »
I think that's an excellent point and one I hadn't considered. In a small loop the only part affected by the varying permittivity of the soil is the capacitor. If that is fully shielded eg by copper tape one could indeed end up with a narrow-band antenna that works independent of the dielectric properties of the immediate environment.
I'm particularly excited about this as all the efficient wide-band antennas I've studied require a prohibitively large antenna at 433 MHz. I had already resigned to use 868 MHz for that very reason - hardly a good idea otherwise because of the much larger signal attenuation in soil at higher frequencies.
« Reply #21 on: May 31, 2016, 02:18:46 AM »
I'm using coax, maybe 30cm. Since I don't use a balun the feedline will modify the antenna characteristics so I've measured it with feedline.
captcha
  • Full Member
  • Country: au
« Reply #22 on: May 31, 2016, 05:04:35 AM »
Reason I'm asking is that this is probably the right time and place to insert a little something about (coax) feedline lengths and how they can pick up radiation from the antenna. Maybe not so much for those in this thread but for everyone else who has questions about how to connect the antenna to the radio this may be of interest.
For those unfamiliar with the relationship between feedline length and how it picks up radiation from the antenna, here's an example that relates to the above dipole antenna.
Apart from the coax' internal dielectric, velocity factor and standing wave ratio, what can become an issue is a phenomenon called 'RF in the shack', relating to 'hot' radio equipment and feedlines that will act as an extension of the radiating antenna and can cause all sorts of nasties (resetting microcontrollers, chip memory corruption, component failure, etc..).
The main reason these 'common mode' currents appear is because of asymmetry of the antenna and using a length of feedline that is resonant at the frequency of operation.
In this case it's not so much the internal dielectric that's responsible for determining how long one physical wavelength in coax is for picking up antenna currents, but the outside braid and its surrounding insulation material. I think I've seen between 0.80 and 0.95 as a velocity factors.
Some sources:
The Dipole and the Coax, L.B. Cebik
My Feedline Tunes My Antenna
Common Mode Current, W8JI
« Reply #23 on: May 31, 2016, 09:41:08 AM »
Another update from Joe Lucid's Antenna Lab:
I built a new loop antenna today, with a diameter of 3.5cm. I tuned it using the VNA, but afterwards fine tuned using RSSI values. I then took a moteino and the th mote with loop antenna on a shootout through the house:
The Moteino is equipped with a rfm69hw, the th mote with a rfm69w. I set both to full power and measured RSSI values at the receiver (an espgw with dipole antenna). Thus I was transmitting with 7dBm more power on the Moteino than the loop.
Not surprisingly RSSI values in the same room with the receiver differed drastically by orientation reflecting the linear polarization of both antennas in perpendicular directions. But starting in the next room there wasn't much difference between the orientations.
Overall the Moteino produced RSSI values between 9dBm and 3dBm better than the loop, depending on the orientation of the Moteino (rotation in its main plane) and inline with the 7dBm higher tx power. The loop produced very omnidirectional radiation across rotations around its axis.
From this data the loop performed just a bit better than the moteino with less variation - much better than my first attempt and pretty respectable given the form factor. That's not to say one can be content with these results as the dipole measurements have shown that significant gains can be had over the monopole over insufficient ground plane approach.
« Reply #24 on: May 31, 2016, 09:47:20 AM »
Today while measuring the new antenna I introduced "hand effect" by positioning my hand right next to the capacitor. Interestingly there was absolutely no effect on frequency, but some decrease in return loss and broadening in bandwidth.
I'm not sure but it felt like this antenna was more robust against influences from the environment than the first one. Which might well be due to its smaller size and thus more magnetic nature.
« Reply #25 on: May 31, 2016, 10:09:48 AM »
Pretty good that it can fit inside a 1.5" PVC pipe (I can use it on my Stream Level sensor, maybe my Landscape lights, and one other landscape related item but I can't remember what it is...).  Now, can you get it to 3cm so I can put it on the wall with the rest of my art work?
By the way, what's that thing hanging off of the Moteino?  It doesn't look like any coin cell I've ever seen!   ;D
« Last Edit: May 31, 2016, 02:35:26 PM by Felix »
« Reply #26 on: May 31, 2016, 10:30:45 AM »
How essential is the vna turning out to be?
« Reply #27 on: June 01, 2016, 03:28:29 AM »
It's definitely very useful. Much better to see return loss or SWR over a full frequency sweep than to fiddle with RSSI measurements. That said with our small motes you do have Heisenberg phenomena where the measuring apparatus influences the results. So it seems useful to still do some RSSI based fine tuning afterwards.
Some of this might be due to my still very primitive use of the VNA and superficial understanding of the RF world.
john4444
  • Jr. Member
« Reply #28 on: June 01, 2016, 12:29:58 PM »
Without that type of tool to "see" what is happening, it is like trying to build something "blind".
Not that it cannot be done but it becomes very difficult and tedious.
Again, very true.
It can be very difficult to duplicate what someone else has already done.
Sometimes, I have trouble even duplicating what I have done with the same setup.
I think that plays a roll in the "black magic" image of radio.
Thank you Felix for providing a low-cost and stable medium to work with.
Not everyone is able to get this combination of components to work as well as you have done.
John AE5HQ
« Reply #29 on: June 01, 2016, 01:29:18 PM »
Yes, no doubt it would be a helpful tool.  However, not having a vna, I've lately been wondering what the alternatives might be.  I'm thinking that with an RTL-SDR, one can perhaps check the radiated frequency well enough to trim one's antenna by doing a progression of snips and seeing if you're getting closer or further away from the desired frequency.  Also, assuming adequate sampling,  RSSI gives you some idea of the radiated power, so I'm guessing that trying a wide enough range of pi-network impedance matching fixes should help identify what sort of adjustment might be needed by noticing which one produces the highest RSSI.  Then repeat that process with a narrower range of adjustments, and continue iterating until satisfied.  Without investing in a vna, is there a better way?
« Last Edit: June 01, 2016, 05:46:21 PM by WhiteHare »
