Small loop antennas @ 433 Mhz
Started by joelucid, May 23, 2016, 03:52:58 PM
QuoteApparently they have a patent (pending) so that might not go so well :)
Well pending doesn't mean granted and granted doesn't mean that there aren't good ideas in there that don't relate to the patent. BTW if there is a patent pending I couldn't find it.
#46
Hmmm..  Looking at the datasheet for the uSplatch and splatch antennas.  If I'm reading them right, they both seem to assume the existence of a proper ground plane:
https://www.linxtechnologies.com/resources/data-guides/ant-916-usp.pdf
https://www.linxtechnologies.com/resources/data-guides/ant-916-sp.pdf
I wonder: would it work to simply attach a sufficiently large uniform antenna ground plane to the back of the moteino with, say, double sided tape so that the splatch has a sufficient counterpoise?  Just solder GND to it with a wire?  It's so simple it's probably worth a try.  I've been meaning to try it underneath just the RFM69 module (execuval already did a very small one to good effect in a different context, so I thought I'd try something bigger), but maybe the RFM69 doesn't need to be separated like that for it to work.  However, lacking the proper measurement equipment, I'm reticent to mess with it, as it might require a lot of blind experimentation to get anywhere with it.
QuoteIf I'm reading them right, they both seem to assume the existence of a proper ground plane
They do require a ground plane, but not a full one. A 433 mhz monopole would need at least a 36cm diameter ground plane disk to be considered fully grounded.
Quotewould it work to simply attach a sufficiently large uniform antenna ground plane to the back of the moteino with, say, double sided tape so that the splatch has a sufficient counterpoise?
In my setup the ground plane on the Moteino serves as antenna ground plane. But yes, adding an uninterrupted ground plane maybe even of the recommended dimensions should certainly improve things. If you put the antenna on top you should also put the ground plane on top to shield components and pcb.
As I said though even the very ad-hoc mounting I used already provided better reception than the wire antenna in my measurement which I found quite sufficient for this purpose (travel kit).
Quote from: joelucid on June 04, 2016, 11:49:10 AM
As I said though even the very ad-hoc mounting I used already provided better reception than the wire antenna in my measurement ...
You mean better eve than the typical straight piece of wire?  Or the loop of wire you've been working on recently (the OP)?
I directly compared a 443mhz Moteino with 17,3 cm wire against the modded Moteino with uSplatch. The uSplatch performed consistently better.
Quote from: joelucid on June 05, 2016, 03:45:29 PM
Is this with the uSplatch perpendicular to the Moteino plane or parallel with it.  I think your photo showed perpendicular but I think Linx specs parallel (ground plane to the pad edge of the antenna).
QuoteIs this with the uSplatch perpendicular to the Moteino plane or parallel with it.  I think your photo showed perpendicular but I think Linx specs parallel (ground plane to the pad edge of the antenna).
Yeah it's with the perpendicular mount that I did just to try it out. I also only connected two of the three pads - one to the antenna out and the other to the gnd pin opposite of the ftdi header. I'm very aware that's not the recommended mount so the results surprised me quite a bit.
#52
Wow, that ranks as a really important find then, and the fact that it's so compact makes it even more awesome.   8)
So, I just ordered a couple to try out.   Hopefully I'll get them by next weekend.
#53
I tried the 915Mhz uSplatch antenna on a node. Looking at the RSSI, it's noticeably more directional, but with a dipole gateway I'm not worrying about it.
I haven't yet tried comparing it to a helical.
Did you also find it performed on average better than the wire?
captcha
As mentioned a few posts back I have finally completed testing and uploaded my dipole-on-pcb boards to OSH park.
See related post on this forum for full details:
https://lowpowerlab.com/forum/rf-range-antennas-rfm69-library/easy-pcb-dipoles-for-433-868-and-915mhz/
@JoeLucid
I'd like to modify my custom temp-rh node's pcb to use a splatch and send it to the fab sometime soon. Looking at the ANT-915-USP datasheet (https://www.linxtechnologies.com/resources/data-guides/ant-916-usp.pdf), I notice it is recommending it be connected to a rather long and wide PCB (3.145" x 1.53") PCB with what looks like a dedicated ground plane.  Have you found the micro splatch to be especially sensitive to those dimensions?  If so, then I might try modifying the bigger experimental node's PCB instead (see attached).
Meh, it was easy enough to add the micro-splatch pads and traces to the small experimental node, so I just now did it and sent it off to the fab.
All monopole type antennas suffer immensely with small ground planes. You'll get much better results with larger ones. But I had fairly good results with a Moteino and splatch - albeit with a connected 9v battery which adds to ground plane size. That's comparing to a Moteino with l/4 monopole which obviously suffers from the same limitations.
Just try it out - I think you'll be surprised by how well they work.
I'm waiting for 3 different trial boards for a th mote with loop antenna. When I converge on a design I'll share here.
I think from now on I'm going to add pads and traces for a Splatch to everything that's experimental.  In the (unlikely) event it doesn't cut the mustard, I'll just un-install and solder a regular wire antenna directly to the RFM69.  In this manner, the option will exist to utilize it if desired, and along the way I'll collect datapoints on where it's effective and where it isn't.  The added PCB board real estate to accommodate its pads is small.
