RFM69HW radio.init() FAIL
Started by LukeTriton, April 19, 2024, 01:18:12 PM
LukeTriton
Hello ! For a university project, I would like to establish a connection between 2 RFM69HW modules to be able to read the RSSI and know if they are more or less far away.I use arduino uno boards.
for this I started from the TxPowerTest_Transmitter and Receiver examples (the most suitable I think for what I want to do?) but I have a problem, I receive in both monitor serie :
" radio.init() FAIL
Transmitting/Receiving at 240 Mhz...
Use:
+,- to adjust power in _powerLevel steps
<,> to adjust power in dBm "
I guess the error comes from the line:
if (!radio.initialize(FREQUENCY,NODEID,NETWORKID))
What can I do to resolve it please ?
There is the code I use :
#include <RFM69.h>      //get it here: https://www.github.com/lowpowerlab/rfm69
#include <RFM69_ATC.h>
#define NODEID        123   //must be unique for each node on same network (range up to 254, 255 is used for broadcast)
#define NETWORKID     100  //the same on all nodes that talk to each other (range up to 255)
#define TONODEID      1    //
//Match frequency to the hardware version of the radio on your Moteino (uncomment one):
#define FREQUENCY     RF69_868MHZ
#define FREQUENCY_EXACT 915500000
#define IS_RFM69HW_HCW   //uncomment only for RFM69HCW! Leave out if you have RFM69CW!
//#define ENABLE_ATC    //comment out this line to disable AUTO TRANSMISSION CONTROL
#define ATC_RSSI -90
#define SERIAL_BAUD   500000
#define DEBUG(input)   Serial.print(input)
#define DEBUGln(input) Serial.println(input)
#define DEBUGHEX(input, param) Serial.print(input, param)
#ifdef ENABLE_ATC
  RFM69_ATC radio/*(10,11) FOR M0 radio add-on board*/;  //#if defined (__AVR_ATmega32U4__) RFM69_ATC radio(8,7);
#else
  RFM69 radio;  //#if defined (__AVR_ATmega32U4__) RFM69 radio(8,7);
#endif
int MODE;
void setup() {
  Serial.begin(SERIAL_BAUD);
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(0, OUTPUT); digitalWrite(0, LOW);
  pinMode(A0, INPUT_PULLUP);
  DEBUGln("START RFM69_NODE_TX_TEST!");
    DEBUGln("radio.init() FAIL");
  else
    DEBUGln("radio.init() SUCCESS");
#ifdef IS_RFM69HW_HCW
  radio.setHighPower(); //only for RFM69HW/HCW!
#endif
#ifdef FREQUENCY_EXACT
  radio.setFrequency(FREQUENCY_EXACT); //set frequency to some custom frequency
#endif
#ifdef ENABLE_ATC
#endif
  char buff[50];
  sprintf(buff, "\nTransmitting at %lu Mhz...", radio.getFrequency()/1000000L);
  DEBUGln(buff);
  DEBUGln("Use:\n+,- to adjust power in _powerLevel steps");
  DEBUGln("<,> to adjust power in dBm");
#ifdef ENABLE_ATC
  DEBUGln("RFM69_ATC Enabled (Auto Transmission Control)\n");
#endif
  MODE = RF69_MODE_SLEEP;
  radio.setMode(MODE);
int8_t dBm=-18; //start at minimum possible value for W/CW, gets bumped by library to -2 for HW/HCW
void loop() {
  if (Serial.available() > 0) {
    char input = Serial.read();
    if (input == 'r') //d=dump register values
      radio.readAllRegsCompact();
    if (input == 'R') //d=dump register values
      radio.readAllRegs();
    if (input=='+') {
      radio.setPowerLevel(radio.getPowerLevel()+1);
      DEBUG("_powerLevel=");DEBUGln(radio.getPowerLevel());
    if (input=='-') {
      if (radio.getPowerLevel()>0) {
        radio.setPowerLevel(radio.getPowerLevel()-1);
    if (input=='<') {
      dBm = radio.setPowerDBm(dBm-1);
      DEBUG("POWER=");DEBUG(dBm);DEBUG(" (dBm); _powerLevel=");DEBUGln(radio.getPowerLevel());
    if (input=='>') {
      dBm = radio.setPowerDBm(dBm+1);
    //transmit mode toggle (enables unmodulated carrier at current power level)
    if (input=='t') {
      if (MODE == RF69_MODE_TX) {
        DEBUG("RADIO_MODE = 0/SLEEP; _powerLevel=");DEBUGln(radio.getPowerLevel());
      else {
        MODE = RF69_MODE_TX;
        DEBUG("RADIO_MODE = 4/TX;    _powerLevel=");DEBUGln(radio.getPowerLevel());
  delay(200);
  if (MODE == RF69_MODE_TX) radio.setMode(MODE);
  else if (digitalRead(A0)==LOW) radio.setMode(RF69_MODE_TX);
  else radio.setMode(RF69_MODE_SLEEP);
How do you connect RFM69 to the UNOs?
Did you do proper level translation?
I would highly recommend not using UNOS, these generate a lot of "why this fails" questions.
LukeTriton
Yes sorry for not specifying it but I use the GT1167 level shifter.
I have these wiring for my two cards :
I thought I read somewhere that an antenna wasn't necessary for the RFM69HW, but maybe I should try adding one?
Our project is supposed to use Arduino boards but if there is no solution what do you advise me to use ? And what modification would be necessary to make ?
#3
No antenna?  ;D ;D ;D ;D
How is the RFM69 supposed to propagate the signal?
240 Mhz?  :o
That tells me your SPI comms to the module through the UNO/shifter is ... not going good.
Try a Moteino, it works well every time!
Usually people try whatever they got on their hand or worse - breadboards and loose wires. Very unreliable for talking to a SPI module.
