RFM69HCW Problem
Started by GjBob, March 14, 2014, 01:37:31 PM
GjBob
Good Evening,since this is my first post hello to all.
I'm trying to integrate the RFM69HCW in my project but i'im having quite some problems. I configure the sender in packet mode(fixed lenght)using only the synch word generation and no address filtering. I tried to transmit a 2 byte packet and got no output on the spectrum analyzer until i enabled PA1 instead of PA0. At this poin i assume that the module is transmitting ( but i'm not 100% sure). On the other side using the same settings but with the module in rx mode waiting for the "PayloadReady" to become high but nothing happens. Here is my register dump , i really can't understand what i'm doing wrong
0x1 - 0x4
0x2 - 0x0
0x3 - 0x1A
0x4 - 0xB
0x5 - 0x3
0x6 - 0x33
0x7 - 0x6C
0x8 - 0x40
0x9 - 0x0
0xA - 0x41
0xB - 0x40
0xC - 0x2
0xD - 0x92
0xE - 0xF5
0xF - 0x20
0x10 - 0x24
0x11 - 0x5F
0x12 - 0x9
0x13 - 0x1A
0x14 - 0x40
0x15 - 0xB0
0x16 - 0x7B
0x17 - 0x9B
0x18 - 0x8
0x19 - 0x86
0x1A - 0x8A
0x1B - 0x40
0x1C - 0x80
0x1D - 0x6
0x1E - 0x10
0x1F - 0x0
0x20 - 0x0
0x21 - 0x0
0x22 - 0x0
0x23 - 0x2
0x24 - 0xFF
0x25 - 0x50
0x26 - 0x5
0x27 - 0x80
0x28 - 0x0
0x29 - 0xDC
0x2A - 0x0
0x2B - 0x0
0x2C - 0x5
0x2D - 0x3
0x2E - 0x88
0x2F - 0xAB
0x30 - 0xBA
0x31 - 0x0
0x32 - 0x0
0x33 - 0x0
0x34 - 0x0
0x35 - 0x0
0x36 - 0x0
0x37 - 0x0
0x38 - 0x2
0x39 - 0xAA
0x3A - 0xFF
0x3B - 0x0
0x3C - 0x80
0x3D - 0x2
0x3E - 0x0
0x3F - 0x0
0x40 - 0x0
0x41 - 0x0
0x42 - 0x0
0x43 - 0x0
0x44 - 0x0
0x45 - 0x0
0x46 - 0x0
0x47 - 0x0
0x48 - 0x0
0x49 - 0x0
0x4A - 0x0
0x4B - 0x0
0x4C - 0x0
0x4D - 0x0
0x4E - 0x1
0x4F - 0x0
0x58 - 0x1B
0x5A - 0x55
0x5C - 0x70
0x6F - 0x0
0x71 - 0x0
croscwa
I believe the RFM69HCW and HW modules need to have their power specifically set. You miht check to see if that was done.
Quote from: croscwa on September 05, 2014, 05:12:58 PM
I'm not sure that's the case. The transceiver chip is the same and hence the firmware usage is the same.
GjBob - not sure how to help since you're not using the LowPowerLab RFM69 library - www.github.com/lowpowerlab/rfm69
