RFM69HC Range Problem
Started by mrmin24, August 04, 2015, 05:23:24 PM
mrmin24
I am unable to get proper reception between two RFM69HC modules. The best RSSI I can manage is -65 with two modules sitting right next to each other. Max range 5 meters.
Each module has a quarter wavelength wire antenna and is powered via a 3.3V breadboard power supply - different power sources give same results. I even tried half wavelength antenna but this made things worse.
I am using the standard RFM69 library config  - 915MHz
Is there something obvious I am missing?
Thanks.
Quote from: mrmin24 on August 04, 2015, 05:23:24 PM
Thanks.
In your code, did you define isRFM69HW?  I know you're using the HC, but to use this device you need to define this constant.
mrmin24,
What hardware are you using (that you connect the RFM69HCW to)?
mrmin24
Thanks TomWS, will give it a try (I think I might have previously, but will try again).
Felix - The gateway is running on an UNO and is connected via level converter. The Node is running on a 5V pro-mini also via level converter.
Thanks thus far
mrmin24
OK!! TomWS your suggestion made a big difference. RSSI is now -35 when radios are close to each other and -67 at about 20m through a couple of walls.
I was still expecting better than that, but I have no baseline to compare. Can you maybe comment on what I should expect?
Quote from: mrmin24 on August 05, 2015, 03:24:00 PM
These numbers look ok although 'close' together I would expect RSSI values in the -20s, but, bear in mind, the RFM69 has a very wide range AGC circuit so even -67 is going to give you good signal quality.  I'm assuming that you've trimmed the antenna wires to the proper length...
What is your transmit power level set to?
mrmin24
Yes, I see that on the node the RSSI when radios are close together is about -10, but the gateway still -35. I did however test up to about 50m and still had RSSI -70 on gateway through multiple walls, so I am happy for now. I will play around with the power settings as I go along. At the moment they are default.
Antennas are 78mm for 915MHz, so... I think this is right
Thanks again for the replies Tom.
