RFM69 Rx and Tx at the same time
Started by mafiat, May 07, 2016, 12:47:15 AM
mafiat
Hi all,
I am new to RFM69 and have a question and need help. Is there a way to receive and transmit at the same time on a RFM69 Module? I am trying to build a irrigation system and want to receive info from the irrigation system and at the same time command the irrigation system.
Appreciate your help.
Mafiat
Quote from: mafiat on May 07, 2016, 12:47:15 AM
Hi all,
Mafiat
EXACTLY the 'same time', no.  Can a node support both send and receive?  Yes, absolutely.
Communication is half duplex - there is one transmitter and one or more receivers at any one instant on the same frequency.  Each node, however, can change roles between transmitting and receiving.  This is a typical Moteino configuration.
mafiat
thanks tom. Do you know of any example handy? If not don't worry, I try to search online. Thanks again.
The RFM69 library includes several examples in its distribution.
