RFM69 Library now works on Spark Core
Started by Charly86, December 07, 2014, 09:04:46 PM
Charly86
Hi Guys,
Just to let you know that latest RFM69 library has been forked and ported to work on Spark Core with few little improvement.
It will be used on a dedicated French specific electrical heating method hardware board
https://github.com/thibdct/programmateur-fil-pilote-wifi/tree/master/Mat%C3%A9riel/1.2
modification of library and explanation are there : https://github.com/hallard/RFM69
bmquist
Can you tell os more about your project? any photos? are you using spark core /particle Photon and RFM69 together, so you skip the red PCB from lowpowerlabs? (just trying to figure out your setup) because I am working on something like that, to minimize parts,
Charly86
@bmquist,
Yeah, for sure, you can see some picture on this blog post
https://hallard.me/particle-gateway/
I'm using Particle Photon and Spark, and since couple of days I've got also a ESP8266 Gateway with RFM69. But I must admit that I'm currently switching all of this to RadioHead library, mainly to get a kind of hardware independency on module used. I plan to test some Lora ;-)
Ric
Hi folks,
I'm having the data corruption issue between my Photon with RFM69 and a moteino with the same transceiver. Using the same code with 2 moteinos I have no issues but once I move the send code to the Photon data packets are sent corrupted. I simply used the examples that came with the RFM69 library and removed the SPI.h and SPIFLASH.h libraries and code associated with them on the Photon.
Photon Code:
    // This #include statement was automatically added by the Particle IDE.
    #include "RFM69/RFM69.h"
    #define NODEID      1
    #define NETWORKID   100
    #define GATEWAYID   99
    #define FREQUENCY   RF69_433MHZ //Match this with the version of your Moteino! (others: RF69_433MHZ, RF69_868MHZ)
    #define KEY         "thisIsEncryptKey" //has to be same 16 characters/bytes on all nodes, not more not less!
    #define LED         D7
    #define SERIAL_BAUD 115200
    #define ACK_TIME    30  // # of ms to wait for an ack
    int TRANSMITPERIOD = 300; //transmit a packet to gateway so often (in ms)
    byte sendSize=0;
    boolean requestACK = false;
    RFM69 radio;
    typedef struct {
      int           nodeId; //store this nodeId
      unsigned long uptime; //uptime in ms
      float         temp;   //temperature maybe?
    } Payload;
    Payload theData;
    void setup() {
      Serial.begin(SERIAL_BAUD);
      //radio.setHighPower(); //uncomment only for RFM69HW!
      radio.encrypt(KEY);
      char buff[50];
      sprintf(buff, "\nTransmitting at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
      Serial.println(buff);
    long lastPeriod = -1;
    void loop() {
      //process any serial input
      if (Serial.available() > 0)
        char input = Serial.read();
        if (input >= 48 && input <= 57) //[0,9]
          TRANSMITPERIOD = 100 * (input-48);
          if (TRANSMITPERIOD == 0) TRANSMITPERIOD = 1000;
          Serial.print("\nChanging delay to ");
          Serial.print(TRANSMITPERIOD);
          Serial.println("ms\n");
        if (input == 'r') //d=dump register values
          radio.readAllRegs();
        //if (input == 'E') //E=enable encryption
        //  radio.encrypt(KEY);
        //if (input == 'e') //e=disable encryption
        //  radio.encrypt(null);
      //check for any received packets
      if (radio.receiveDone())
        Serial.print('[');Serial.print(radio.SENDERID, DEC);Serial.print("] ");
          Serial.print((char)radio.DATA[i]);
        Serial.print("   [RX_RSSI:");Serial.print(radio.readRSSI());Serial.print("]");
        if (radio.ACKRequested())
          radio.sendACK();
          Serial.print(" - ACK sent");
          delay(10);
        Blink(LED,5);
        Serial.println();
      int currPeriod = millis()/TRANSMITPERIOD;
      if (currPeriod != lastPeriod)
        //fill in the struct with new values
        theData.nodeId = NODEID;
        theData.uptime = millis();
        theData.temp = 91.23; //it's hot!
        Serial.print("Sending struct (");
        Serial.print(sizeof(theData));
        Serial.print(" bytes) ... ");
        if (radio.sendWithRetry(GATEWAYID, (const void*)(&theData), sizeof(theData)))
          Serial.print(" ok!");
        else Serial.print(" nothing...");
        Serial.println();
        Blink(LED,3);
        lastPeriod=currPeriod;
      pinMode(PIN, OUTPUT);
      digitalWrite(PIN,HIGH);
      delay(DELAY_MS);
      digitalWrite(PIN,LOW);
Moteino Code:
    #include <RFM69.h>
    #include <SPI.h>
    #include <SPIFlash.h>
    #define NODEID      99
    #define LED         9
    RFM69 radio;
    SPIFlash flash(8, 0xEF30); //EF40 for 16mbit windbond chip
    bool promiscuousMode = false; //set to 'true' to sniff all packets on the same network
    typedef struct {
    } Payload;
    Payload theData;
    void setup() {
      delay(10);
      radio.encrypt(KEY);
      radio.promiscuous(promiscuousMode);
      char buff[50];
      sprintf(buff, "\nListening at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
      if (flash.initialize())
        Serial.println("SPI Flash Init OK!");
      else
        Serial.println("SPI Flash Init FAIL! (is chip present?)");
    byte ackCount=0;
    void loop() {
        if (input == 'r') //d=dump all register values
          radio.encrypt(KEY);
        if (input == 'p')
          promiscuousMode = !promiscuousMode;
          Serial.print("Promiscuous mode ");Serial.println(promiscuousMode ? "on" : "off");
        if (input == 'd') //d=dump flash area
          Serial.println("Flash content:");
          int counter = 0;
          while(counter<=256){
            Serial.print(flash.readByte(counter++), HEX);
            Serial.print('.');
          while(flash.busy());
          Serial.println();
        if (input == 'D')
          Serial.print("Deleting Flash chip content... ");
          flash.chipErase();
          Serial.println("DONE");
        if (input == 'i')
          Serial.print("DeviceID: ");
          word jedecid = flash.readDeviceId();
          Serial.println(jedecid, HEX);
        if (promiscuousMode)
          Serial.print("to [");Serial.print(radio.TARGETID, DEC);Serial.print("] ");
        if (radio.DATALEN != sizeof(Payload))
          Serial.print("Invalid payload received, not matching Payload struct!");
        else
          theData = *(Payload*)radio.DATA; //assume radio.DATA actually contains our struct and not something else
          Serial.print(" nodeId=");
          Serial.print(theData.nodeId);
          Serial.print(" uptime=");
          Serial.print(theData.uptime);
          Serial.print(" temp=");
          Serial.print(theData.temp);
          radio.sendACK();
          Serial.print(" - ACK sent.");
          // When a node requests an ACK, respond to the ACK
          // and also send a packet requesting an ACK (every 3rd one only)
          // This way both TX/RX NODE functions are tested on 1 end at the GATEWAY
          if (ackCount++%3==0)
            Serial.print(" Pinging node ");
            Serial.print(theNodeID);
            Serial.print(" - ACK...");
            delay(3); //need this when sending right after reception .. ?
            if (radio.sendWithRetry(theNodeID, "ACK TEST", 8, 0))  // 0 = only 1 attempt, no retries
              Serial.print("ok!");
            else Serial.print("nothing");
        Serial.println();
        Blink(LED,3);
      delay(DELAY_MS);
I left the SPI.h and SPIFLASH.h libraries on the Moteino code because it does have the flash memory chip installed.
I'm getting a message saying "Invalid payload received, not matching Payload struct!" because the size of the struct received is not matching the format on hand even through they both do have the same format.
Could the RFM69 chip be having a timing issue because the Photon is so much faster than the ATmega328P on the Moteino?
Any help would be greatly appreciated.
Thanks in advance!
Charly86
@Ric,
this is because Photon compiler does not align struct on byte but on 4 bytes, you  need to use #pragma directive as follow
#ifdef SPARK
  // This will force structure to 1 byte alignment
  #pragma pack(push)  // push current alignment to stack
  #pragma pack(1)     // set alignment to 1 byte boundary
#endif
 // Put your struct declaration here
 typedef struct {
    } Payload;
    Payload theData;
#ifdef SPARK
  // restore original alignment from stack
  #pragma pack(pop)
#endif
then should be working fine ;-)
You can see example in ULPNode RF Protocol definition file
https://github.com/hallard/ULPNode_RF_Protocol/blob/master/ULPNode_RF_Protocol.h
Ric
Thanks for the quick response Charly! Unfortunately I'm still getting the same message. What could possibly be wrong?? Do you have different code that works for you that I could try?
Thanks again.
Charly86
#6
humm not sure int is same size on both side, Could you try with this struct on both side
 typedef struct {
      uint8_t           nodeId; //store this nodeId
    } Payload;
    Payload theData;
and add in setup the following code and check displayed size is same on both side ?
Serial.print("Struct size=");
Serial.println(" bytes");
And to be sure, my first post about pragma is for Spark side
Anyway, here a project with Felix's code working but there is lot of files on it. I remember I modifed some lines in orginal RFM69 code but I don't remember which ones.
https://github.com/thibdct/programmateur-fil-pilote-wifi/tree/00e4aec1baa10f3e694f9c0b58795ea083873f0c/Logiciel/remora
It's pretty old because now I've swhitched to radiohead on my Particle Gateway.
Ric
The Photon says that it's sending 9 and the Moteino says that it's receiving 10.  :o
Ric
I changed the code on the Moteino to:
    if (radio.DATALEN != sizeof(Payload) - 1)
      Serial.print(" bytes");
So that by subtracting a byte it would match just to see what was coming out of the struct and this is what I got:
[1]  [RX_RSSI:-29] nodeId=-11263 uptime=3271559368 temp=0.00 - ACK sent.
[1]  [RX_RSSI:-29] nodeId=-11263 uptime=3271559368 temp=0.00 - ACK sent. Pinging node 1 - ACK...nothing
[1]  [RX_RSSI:-28] nodeId=1 uptime=3271559370 temp=0.00 - ACK sent.
[1]  [RX_RSSI:-29] nodeId=1 uptime=3271559370 temp=0.00 - ACK sent.
[1]  [RX_RSSI:-28] nodeId=1 uptime=3271559370 temp=0.00 - ACK sent. Pinging node 1 - ACK...nothing
[1]  [RX_RSSI:-28] nodeId=11265 uptime=3271559371 temp=0.00 - ACK sent.
[1]  [RX_RSSI:-28] nodeId=11265 uptime=3271559371 temp=0.00 - ACK sent. Pinging node 1 - ACK...nothing
[1]  [RX_RSSI:-29] nodeId=22529 uptime=3271559372 temp=0.00 - ACK sent.
[1]  [RX_RSSI:-28] nodeId=22529 uptime=3271559372 temp=0.00 - ACK sent.
[1]  [RX_RSSI:-28] nodeId=22529 uptime=3271559372 temp=0.00 - ACK sent. Pinging node 1 - ACK...nothing
[1]  [RX_RSSI:-28] nodeId=-31743 uptime=3271559373 temp=0.00 - ACK sent.
[1]  [RX_RSSI:-29] nodeId=-31743 uptime=3271559373 temp=0.00 - ACK sent.
[1]  [RX_RSSI:-28] nodeId=-31743 uptime=3271559373 temp=0.00 - ACK sent. Pinging node 1 - ACK...nothing
[1]  [RX_RSSI:-29] nodeId=-20479 uptime=3271559374 temp=0.00 - ACK sent.
[1]  [RX_RSSI:-28] nodeId=-20479 uptime=3271559374 temp=0.00 - ACK sent.
[1]  [RX_RSSI:-28] nodeId=-20479 uptime=3271559374 temp=0.00 - ACK sent. Pinging node 1 - ACK...nothing
[1]  [RX_RSSI:-28] nodeId=-9215 uptime=3271559375 temp=0.00 - ACK sent.
Also and just to make sure that I understood your directions correctly. Here is my Photon code:
#define NODEID      1
#define LED         D7
byte sendSize=0;
RFM69 radio;
#ifdef SPARK
#endif
 typedef struct {
    } Payload;
    Payload theData;
#ifdef SPARK
  #pragma pack(pop)
#endif
void setup() {
  delay(10);
  radio.encrypt(KEY);
  radio.setIRQ(D2);
  radio.setBaudRate(60000);
  char buff[50];
  Serial.println();
void loop() {
      radio.sendACK();
      delay(10);
    Blink(LED,5);
    Serial.println();
    Serial.println();
    Blink(LED,3);
  delay(DELAY_MS);
And here is my Moteino code the only part I changed was:
Charly86
Humm, sounds strange that moteino is 2 bytes aligned is it moteino or moteino mega ?
Woud you try with pack 2 bytes instead on 1,
#pragma pack(2)     // set alignment to 2 bytes boundary
Ric
That's it! Packing 2 bytes worked!!!!
By the way, I'm using just a regular Moteino, not the mega.
Thank you so so so much for your help!
Charly86
may be another idea would be to set the same #pragma directive on both sketches without any #ifdef to be sure they're all the same
just put on each sketch the following line, moteino should now says size of 9 bytes
Charly86
great it worked,
I was not aware moteino is 2 bytes aligned, I was sure it was 1 and never set this option on Arduino side and always worked.
So I've got 2 options :
- new compiler version is now aligning to 2 bytes
- I was always lucky to get all my structures 2 bytes aligned between arduino and Spark/ESP8266 ;-)
I will correct my code just in case ;-)
thanks pointing out on this
Ric
***UPDATE***
Hi Charly,
On the Photon sketch that I actually use my struct was
typedef struct {
  char        Type;
  int           ID;
  char        Action;
  int           Var1;
  int           Var2;
  int           Var3;
} Payload;
Payload theData;
After changing the struct to
typedef struct {
  byte            Type;
  int16_t           ID;
  byte            Action;
  int16_t           Var1;
  int16_t           Var2;
  int16_t           Var3;
} Payload;
Payload theData;
I only needed to align 1 byte, not 2. With this I didn't have to make any modification on the Moteino.
