RF69HW Transmitting Code
Started by laspenciabrown, October 13, 2016, 11:37:02 PM
laspenciabrown
This is the transmitting code I'm using
/* RFM69 library and code by Felix Rusu - [email protected]
// Get libraries at: https://github.com/LowPowerLab/
// Make sure you adjust the settings in the configuration section below !!!
// Copyright Felix Rusu, LowPowerLab.com
// Library and code by Felix Rusu - [email protected]
// License
// This program is free software; you can redistribute it
// and/or modify it under the terms of the GNU General
// Public License as published by the Free Software
// Foundation; either version 3 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will
// be useful, but WITHOUT ANY WARRANTY; without even the
// implied warranty of MERCHANTABILITY or FITNESS FOR A
// PARTICULAR PURPOSE. See the GNU General Public
// License for more details.
// You should have received a copy of the GNU General
// Public License along with this program.
// If not, see <http://www.gnu.org/licenses></http:>.
// Licence can be viewed at
// http://www.gnu.org/licenses/gpl-3.0.txt
// Please maintain this license information along with authorship
// and copyright notices in any redistribution of this code
#include <SPI.h>
// *********** IMPORTANT SETTINGS - YOU MUST CHANGE/ONFIGURE TO FIT YOUR HARDWARE *************
#define NETWORKID     100  // The same on all nodes that talk to each other
#define NODEID        2    // The unique identifier of this node
#define RECEIVER      1    // The recipient of packets
//Match frequency to the hardware version of the radio on your Feather
#define IS_RFM69HCW   true // set to 'true' if you are using an RFM69HCW module
#define SERIAL_BAUD   115200
#define RFM69_CS      10
#define RFM69_IRQ     2
#define RFM69_IRQN    0  // Pin 2 is IRQ 0!
#define RFM69_RST     9
#define LED           13  // onboard blinky
int16_t packetnum = 0;  // packet counter, we increment per xmission
RFM69 radio = RFM69(RFM69_CS, RFM69_IRQ, IS_RFM69HCW, RFM69_IRQN);
void setup() {
  while (!Serial); // wait until serial console is open, remove if not tethered to computer
  Serial.begin(SERIAL_BAUD);
  Serial.println("Arduino RFM69HCW Transmitter");
  // Hard Reset the RFM module
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, HIGH);
  delay(100);
  digitalWrite(RFM69_RST, LOW);
  delay(100);
  // Initialize radio
  if (IS_RFM69HCW) {
    radio.setHighPower();    // Only for RFM69HCW & HW!
  radio.setPowerLevel(31); // power output ranges from 0 (5dBm) to 31 (20dBm)
  radio.encrypt(ENCRYPTKEY);
  pinMode(LED, OUTPUT);
  Serial.print("\nTransmitting at ");
  Serial.print(FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
  Serial.println(" MHz");
void loop() {
  delay(1000);  // Wait 1 second between transmits, could also 'sleep' here!
  char radiopacket[20] = "Hello World #";
  itoa(packetnum++, radiopacket+13, 10);
  Serial.print("Sending "); Serial.println(radiopacket);
  if (radio.sendWithRetry(RECEIVER, radiopacket, strlen(radiopacket))) { //target node Id, message as string or byte array, message length
    Serial.println("OK");
    Blink(LED, 50, 3); //blink LED 3 times, 50ms between blinks
  radio.receiveDone(); //put radio in RX mode
  Serial.flush(); //make sure all serial data is clocked out before sleeping the MCU
void Blink(byte PIN, byte DELAY_MS, byte loops)
  for (byte i=0; i<loops; i++)
    digitalWrite(PIN,HIGH);
    delay(DELAY_MS);
    digitalWrite(PIN,LOW);
    delay(DELAY_MS);
This is what my serial monitor displaying:
°¦õ¼QÿðÅðÅðÅðŸ¦õ¼ÿ°...°ÅðÅðÅðÅð...ðÅøÅø...
Why is this happening?
Wrong serial monitor baud rate maybe? Do your encryption keys match?
PS. Please don't post the same thing in several different places. A single thread is enough.
laspenciabrown
I;m trying to use this test:
https://learn.adafruit.com/adafruit-rfm69hcw-and-rfm96-rfm95-rfm98-lora-packet-padio-breakouts/rfm69-test
but I'm unable to open two serial monitors at the same time.
So when I upload the TX code and plug that into an outlet and upload the RX code and open it on the serial monitor on the PC and it doesn't transmit or receive at all.
So what exactly is your hardware?
