Noise level
Started by Vorms, December 25, 2018, 08:00:44 PM
Vorms
I have a noise problem.
I see when the transmitter will send a message, before sending he is hearing about.
If the receive receive someting, the transmitter will no transmit the message until the chanel is free.
That is if I understand well the role of the canSend method
Some times, in my envirronement the waste time can be one second !
For dealing with the noise, I add a method for changing the noise level of the receiver
I am not in a special environnement, I use the RFM69X Library with an ESP32
Am i correct ?
Best regard and marry Chrismass!
Quote from: Vorms on December 25, 2018, 08:00:44 PM
That's likely your problem.
Search around in the forum, you will find some threads where pairing RFM69 with ESP modules causes a noise problem for the RFM69. Those threads also discuss some solutions for this problem.
vc1234
I had  similar experience with RFM69 connected to ESP8266 and ESP32. In my case, I received garbage at -90/-92 RSSI with a 5 bytes preamble and a two byte sync word meaning that noise was treated as real data. One 8266 was the worst(several incorrect frames per minute),another slightly better, and an ESP32 TTGO had the least noise (about one packet per hour). In comparison a Moteino and a 8MHz Pro Mini received about one /two noise as "correct" frame/packet a day.
Interestingly, an RPI zero W which I use as a gateway with an RFM69 produced less noise than ESP8266/32.  Not sure how to filter the noise out (if it's even possible at all with boards I use) since I'd prefer to use an 8266 as a gateway to MQTT rather than an RPI.
Lets see if TomWS will have a say, he's a big fan of ESP boards :)
