min antenna distance
Started by ulli, August 18, 2015, 09:03:11 AM
ulli
I plan to use 3 different RFM69 modules next to each other. One 433Mhz and two 868Mhz modules with a distance between two antennas of ~2cm.
I am thinking about if there is an advantage or disadvantage in the order of the modules/antennas.
e.g. 868Mhz – 433Mhz - 868Mhz     or   868Mhz - 868Mhz - 433Mhz
Do you think it does anyhow make a difference?
ulli
no proposals?
I think  868Mhz – 433Mhz - 868Mhz would be best?
If you're asking for an opinion, mine is that it should not make a difference.
Doing a real test is far better than a guess  ::)
ulli
