LoRa w/encryption - RH95
Started by syrinxtech, July 18, 2020, 08:04:12 AM
syrinxtech
Does anyone have experience using the RadioHead libraries with the "arduinolibs" encryption software by Rhys Weatherly?  Specifically, I'm trying to combine the RHEncryptedDriver, the RH95 transport driver and the RHReliableDatagram manager.  With Rhys's help, I was able to get the basic encryption (Speck) working but when I tried to add reliable datagrams (for addressing and retries) it no longer worked.  I saw a line in the RH docs that said "under certain circumstances" it was possible to combine multiple drivers and/or managers but it was beyond my ability to make it work.
If you have done something similar to what I'm describing above, I would love to hear the specifics how you got it all working together.
luisgcu
I am just trying that combination and isn't working for  me. Did you figure out how to get
RH_95 + RHEncryptedDriver +RHReliableDatagram to work properly?
..Knowing other is wisdom,
knowing yourself is Enlightenment..
syrinxtech
@luisgcu,
I never got it working.  Since then I've moved on from the RH95 chips and went mainstream LoRA and LoRAWAN which adds encryption.
