Loop antennas revisited
Started by tve, January 27, 2019, 02:44:36 PM
tve
I'm re-reading @joelucid's 2016 thread on small loop antennas (https://lowpowerlab.com/forum/rf-range-antennas-rfm69-library/small-loop-antennas-433-mhz) and I wonder whether anyone has experimented some more and come to a final design?
I'm actually more interested in 915Mhz than 433Mhz and I just came across the Taoglas ILA.01 10mm x 3.2mm x 0.5mm ceramic small loop antenna which claims a peak gain of 1dBi. Although they did measure using a sizeable 80mm x 40mm ground plane... I wonder whether this antenna has the same benefits as Joe's loops (low noise and less detuning by nearby objects/hands)... Sadly it's $13 @qty1 at digikey, goes down to a more acceptable $3 in large volume at mouser...
Taoglas web page for this antenna: https://www.taoglas.com/product/ila-01-915mhz-ceramic-loop-antenna/
Web page for similar antennas: https://www.taoglas.com/product-category/ism-135-169-443-450-784-868-915-mhz/internal-ism/
