I have a home alarm that is on the 868Mhz band, all the sensors use CC1101 to communicate with the alarm central, and I'm trying to listen to a few things in order to interact with a Home Assistant installation I have.
After recording some communications with URH, I ended up with pretty good knowledge about the signal going around, it's center frequency is 868,250Mhz 40khz deviation, 38400baud, 4 preamble bytes and sync 2 bytes. In the attachment, you guys can see the analysis, with the preamble, sync, I'm guessing it's an node id after (not length, as it doesn't match the packet length), data, and hidden is what I think to be the CRC, some of the data I can figure out what it is (partial serial number of the device) the rest not really yet.
The point is, I have a RFM69HCW, and I'm trying to configure so that I can receive packets from these sensors, unfortunately, to no avail....
I have edited RFM69.cpp the initialize method, to set the registers according to the data above;
/* 0x01 */ { REG_OPMODE, RF_OPMODE_SEQUENCER_ON | RF_OPMODE_LISTEN_OFF | RF_OPMODE_STANDBY },
/* 0x02 */ { REG_DATAMODUL, RF_DATAMODUL_DATAMODE_PACKET | RF_DATAMODUL_MODULATIONTYPE_FSK | RF_DATAMODUL_MODULATIONSHAPING_00 }, // no shaping
/* 0x03 */ { REG_BITRATEMSB, RF_BITRATEMSB_38400},
/* 0x04 */ { REG_BITRATELSB, RF_BITRATELSB_38400},
/* 0x05 */ { REG_FDEVMSB, RF_FDEVMSB_40000},
/* 0x06 */ { REG_FDEVLSB, RF_FDEVLSB_40000},
/* 0x07 */ { REG_FRFMSB, (uint8_t) (freqBand==RF69_315MHZ ? RF_FRFMSB_315 : (freqBand==RF69_433MHZ ? RF_FRFMSB_433 : (freqBand==RF69_868MHZ ? RF_FRFMSB_868 : RF_FRFMSB_915))) },
/* 0x08 */ { REG_FRFMID, (uint8_t) (freqBand==RF69_315MHZ ? RF_FRFMID_315 : (freqBand==RF69_433MHZ ? RF_FRFMID_433 : (freqBand==RF69_868MHZ ? RF_FRFMID_868 : RF_FRFMID_915))) },
/* 0x09 */ { REG_FRFLSB, (uint8_t) (freqBand==RF69_315MHZ ? RF_FRFLSB_315 : (freqBand==RF69_433MHZ ? RF_FRFLSB_433 : (freqBand==RF69_868MHZ ? RF_FRFLSB_868 : RF_FRFLSB_915))) },
// looks like PA1 and PA2 are not implemented on RFM69W/CW, hence the max output power is 13dBm
// +17dBm and +20dBm are possible on RFM69HW
// +13dBm formula: Pout = -18 + OutputPower (with PA0 or PA1**)
// +17dBm formula: Pout = -14 + OutputPower (with PA1 and PA2)**
// +20dBm formula: Pout = -11 + OutputPower (with PA1 and PA2)** and high power PA settings (section 3.3.7 in datasheet)
///* 0x11 */ { REG_PALEVEL, RF_PALEVEL_PA0_ON | RF_PALEVEL_PA1_OFF | RF_PALEVEL_PA2_OFF | RF_PALEVEL_OUTPUTPOWER_11111},
///* 0x13 */ { REG_OCP, RF_OCP_ON | RF_OCP_TRIM_95 }, // over current protection (default is 95mA)
// RXBW defaults are { REG_RXBW, RF_RXBW_DCCFREQ_010 | RF_RXBW_MANT_24 | RF_RXBW_EXP_5} (RxBw: 10.4KHz)
/* 0x19 */ { REG_RXBW, RF_RXBW_DCCFREQ_010 | RF_RXBW_MANT_24| RF_RXBW_EXP_3 }, // (BitRate < 2 * RxBw)
//for BR-19200: /* 0x19 */ { REG_RXBW, RF_RXBW_DCCFREQ_010 | RF_RXBW_MANT_24 | RF_RXBW_EXP_3 },
/* 0x25 */ { REG_DIOMAPPING1, RF_DIOMAPPING1_DIO0_01 }, // DIO0 is the only IRQ we're using
/* 0x26 */ { REG_DIOMAPPING2, RF_DIOMAPPING2_CLKOUT_OFF }, // DIO5 ClkOut disable for power saving
/* 0x28 */ { REG_IRQFLAGS2, RF_IRQFLAGS2_FIFOOVERRUN }, // writing to this bit ensures that the FIFO & status flags are reset
/* 0x29 */ { REG_RSSITHRESH, 220 }, // must be set to dBm = (-Sensitivity / 2), default is 0xE4 = 228 so -114dBm
/* 0x2D */ { REG_PREAMBLELSB, RF_PREAMBLESIZE_LSB_VALUE }, // default 3 preamble bytes 0xAAAAAA
/* 0x2E */ { REG_SYNCCONFIG, RF_SYNC_ON | RF_SYNC_FIFOFILL_AUTO | RF_SYNC_SIZE_3 | RF_SYNC_TOL_0 },
/* 0x2F */ { REG_SYNCVALUE1, 0x45 }, // attempt to make this compatible with sync1 byte of RFM12B lib
/* 0x30 */ { REG_SYNCVALUE2, 0x53 }, // NETWORK ID
//* 0x31 */ { REG_SYNCVALUE3, 0xAA },
//* 0x31 */ { REG_SYNCVALUE4, 0xBB },
/* 0x37 */ { REG_PACKETCONFIG1, RF_PACKET1_FORMAT_VARIABLE | RF_PACKET1_DCFREE_OFF | RF_PACKET1_CRC_OFF | RF_PACKET1_CRCAUTOCLEAR_ON | RF_PACKET1_ADRSFILTERING_OFF },
/* 0x38 */ { REG_PAYLOADLENGTH, 255 }, // in variable length mode: the max frame size, not used in TX
///* 0x39 */ { REG_NODEADRS, nodeID }, // turned off because we're not using address filtering
/* 0x3C */ { REG_FIFOTHRESH, RF_FIFOTHRESH_TXSTART_FIFONOTEMPTY | RF_FIFOTHRESH_VALUE }, // TX on FIFO not empty
/* 0x3D */ { REG_PACKETCONFIG2, RF_PACKET2_RXRESTARTDELAY_2BITS | RF_PACKET2_AUTORXRESTART_OFF | RF_PACKET2_AES_OFF }, // RXRESTARTDELAY must match transmitter PA ramp-down time (bitrate dependent)
//for BR-19200: /* 0x3D */ { REG_PACKETCONFIG2, RF_PACKET2_RXRESTARTDELAY_NONE | RF_PACKET2_AUTORXRESTART_ON | RF_PACKET2_AES_OFF }, // RXRESTARTDELAY must match transmitter PA ramp-down time (bitrate dependent)
/* 0x6F */ { REG_TESTDAGC, RF_DAGC_IMPROVED_LOWBETA0 }, // run DAGC continuously in RX mode for Fading Margin Improvement, recommended default for AfcLowBetaOn=0
{255, 0}
I tried with Sync on and off, crc check and without, even set a pin toggle in the interrupt handler to figure out if any packet at all is being received, but, without any success.... main code is very simple, based on the gateway example, just sets the center frequency and enables spy mode, I can read the registers in the terminal, the all seem correct, but still, no packet is ever received.....
Any thoughts ?
