Best settings for long range?
Started by brolly759, August 21, 2019, 12:13:23 PM
brolly759
I have been playing around with changing the bit-rate from 1200 to 4800(default) to get the best range in a long distance vertical run. Obviously 1200 gets the best distance but for a battery powered solution where I need ACKs, it takes too long. Ideally I would like to use the default settings but extend the range if its possible with a settings change. Here are my settings and findings, is there anything I can do differently?
4800 - Default settings
radio.writeReg(0x58, 0x2D);
2400 settings:
radio.writeReg(0x03,0x34);      //RegBitrateMsb 2400 bitrate
radio.writeReg(0x04,0x15);      //RegBitrateLsb 2400 bitrate
radio.writeReg(0x05,0x00);      //RegFdevMsb     2000
radio.writeReg(0x06,0x52);      //RegFdevLsb     2000
radio.writeReg(0x19,0x40|0x10|0x05);      //RegRxBw  DccFreq:010, RxBw_Mant:24, RxBw_Exp:5
radio.writeReg(0x18,0x00|0x00|0x01);      //RegLna  LnaZin:50ohm, LowPower:Off, CurrentGain:MAX
1200 settings:
//radio.writeReg(0x03,0x68);      //RegBitrateMsb 1200 bitrate
//radio.writeReg(0x04,0x2B);      //RegBitrateLsb 1200 bitrate
I got rid of sendWithRetry and used standard send and receive in while loop to time the difference in TX / RX timing.
4.8Kbps Timing Test:
13   [RX_RSSI:-35
ms to receive message: 7
ms to Transmit message: 4
_____________________________
14   [RX_RSSI:-35
ms to receive message: 6
ms to Transmit message: 6
15   [RX_RSSI:-35
2.4kbps Timing Test:
251   [RX_RSSI:-33
ms to receive message: 92
ms to Transmit message: 84
252   [RX_RSSI:-33
ms to receive message: 88
253   [RX_RSSI:-34
ms to receive message: 145
1.2kbps Timing Test
3   [RX_RSSI:-34
ms to receive message: 172
ms to Transmit message: 168
4   [RX_RSSI:-34
ms to Transmit message: 166
5   [RX_RSSI:-33
ms to receive message: 170
