Wireless baterrypower sensors (temp,door,motio) + raspberry
Started by donvonhill, May 29, 2014, 10:57:22 AM
donvonhill
Hi all,
I have plan to make 5 wireless temp sensors(ds18b20) power by battery and sending data to raspberry(with another moteino-r4) and publish them on webside. Am I able to build this with moteino?
What are basic parts for this?
wireless sensor
1x moteino-r4
1x ds18b20 - is there any another alternative
9v battery
raspberry
1x moteino-r4
Is it possible to connect ds18b20 straight to moteino? How can I connect moteino-r4 to raspberry? Through gpio? Sorry for these greenhorn question but I am not able to google it :-(
Can you please help me with it?
Many thanks for your help!
Petr
luisr320
I'm sure you can do all that stuff and it will be easy if you use the moteinos. Search on Google but use "arduino" instead of "moteino".
there will be plenty of help available here too. Unfortunately I'm still in denial regarding the whole raspberry Pi scene and can't assist you there.
Keep us posted on your project.
Look for other topics in the forum regarding the DS temp sensor, people have posted code and how they wired it. So it's possible. You will need to sleep your wireless nodes as much as possible to get any decent battery life. On the Pi side all you need to do is load it with the Gateway sample sketch (adjust settings for your radio), then connect power and serial (RX, TX) to the Moteino, then it's ready to receive packets and send them to the Pi through the serial. You will need to enable the Pi serial as shown here: https://lowpowerlab.com/forum/index.php/topic,496.msg2786.html#msg2786
ColinR
cupidcontrols.com
