LowPowerLab Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Home
Blog
Shop
Help
Search
Login
Register
LowPowerLab Forum
Hardware support
Projects
RFM69W Breakout Board
Print
Pages: [
1
Author
Topic: RFM69W Breakout Board (Read 4123 times)
uChip
Newbie
on:
February 09, 2014, 01:46:14 PM »
I wanted to experiment with the RFM69W radio on my existing Arduinos so I created a breakout board. The board has the same edge pinout as the RFM12B Board from JeeLabs so you can swap between them.
Details are here:
https://github.com/uChip/RFM69W_BOB
You can order the board from Osh Park here:
http://oshpark.com/shared_projects/bJRprI06
$6.75 for three boards (PCBs only).
Note that the board is NOT compatible with the RFM12B or the RFM69CW. Use the JeeLabs board for those.
Have fun.
- Chip
Logged
jra
Jr. Member
Country:
Re: RFM69W Breakout Board
Reply #1 on:
February 10, 2014, 02:08:18 PM »
Excellent! I ordered a few RFM69HW transceivers awhile ago and was going to hack up a solution that would allow me to plug them into a breadboard, decided to order your breakout boards instead.
Logged
uChip
Newbie
Reply #2 on:
February 11, 2014, 11:14:49 AM »
Cool. According to the mechanical drawings that should work fine, but I haven't tested with the 'HW. Let us know how it goes.
Logged
Vince
Newbie
Reply #3 on:
February 11, 2014, 09:00:48 PM »
uChip,
Nice idea on the Breakout Board, especially the level shifting resistor option. Do you have a parts list available for use with the Board? I just ordered three.
Thanks,
Vince
Logged
uChip
Newbie
Reply #4 on:
February 12, 2014, 09:55:38 PM »
Here is the order list
Qty
Parts
Value
Mfg Part #
Description / Vendor
1
JP1
8-pins
Break Away Male Headers - Right Angle
https://www.sparkfun.com/products/553
1
PCB
2
C1, C2
0.1uF
C2012X7R2A104K125AA
CAP CER 0.1UF 100V 10% X7R 0805; Digi-Key #445-1418-1-ND
3
R4, R5, R6
10k
CRT0805-BY-1002ELF
RES 10K OHM 1/8W .1% 0805 SMD; Digi-Key #CRT0805-BY-1002ELFCT-ND
1
C4
10uF
F951A106MRAAQ2
CAP TANT 10UF 10V 20% 0805; Digi-Key #478-8418-1-ND
3
R1, R2, R3
4k7
ERJ-6GEYJ472V
RES 4.7K OHM 1/8W 5% 0805 SMD; Digi-Key #P4.7KACT-ND
1
U2
MCP1701
MCP1701AT-3302I/MB
IC REG LDO 3.3V 0.15A SOT89-3; Digi-Key #MCP1701AT-3302I/MBCT-ND
1
U1
RFM69W
RFM69W-S2
http://lowpowerlab.com/shop/RFM69W
And here is the parts list
Part
Value
Device
Package
C1
0.1uF
CAP0805
0805
Capacitor
C2
0.1uF
CAP0805
0805
Capacitor
C4
10uF
CAP_POL0805
0805-POL
JP1
8pins
1X08_RIGHT_ANGLE
Header 8
R1
4k7
RESISTOR0805-RES
0805
Resistor
R2
4k7
RESISTOR0805-RES
0805
Resistor
R3
4k7
RESISTOR0805-RES
0805
Resistor
R4
10k
RESISTOR0805-RES
0805
Resistor
R5
10k
RESISTOR0805-RES
0805
Resistor
R6
10k
RESISTOR0805-RES
0805
Resistor
U1
RFM69W
RFM69W
RFM69W
Radio Transceiver Module, FSK, 433, 848, 915 MHz, SPI controlled, Mfr=HopeRF
U2
MCP1701
MCP1701
SOT-89
Voltage Regulator, LDO, fixed 1.8,2.5,3.0,3.3,5.0V, 500mW/Vdrop
Note that all parts are "or equivalent". These are the parts I tested with, but you can probably substitute parts with no impact on function. For instance, any 0805 package 10k resistor would be fine.
Do check the repo document as not all parts are needed in all applications.
I will also add this info to the github repo.
- Chip
Logged
chalupien
Newbie
Reply #5 on:
March 19, 2014, 02:02:39 PM »
Hi Why use a voltage divider vs a level shifting chip? Pro's/Cons?
Logged
Administrator
Hero Member
Country:
Reply #6 on:
March 19, 2014, 07:36:21 PM »
Resistors will work just fine, cheapest option.
You can also use FETs or dedicated chips for level shifting, these are more complex/expensive solutions. For hobby stuff resistors are fine, if you are the military you might want shifting chips
Logged
Print
Pages: [
1
LowPowerLab Forum
Hardware support
Projects
