Building Gateway and it looks good until now. I can run PHP info fine. I tried to install nodejs with apt-get. nodejs.org had link to "Installing from package managers" and it seemed to me that a year had elapsed since Felix installed from binaries so it might work. It seemed to install properly, first in /usr/bin/nodejs. Since /usr/bin was already in PATH I thought it would work. When I ran node -v I got a command not found message. That was with sudo or without. I moved nodejs to /opt/node, changed the path, logged out, then in and tried again. Same result. I've read the forums. No one else seems to have had this problem.
I have no problem with purging the install and re-installing via binary but it seems like that might be overkill. Anybody got any hints for me?
