Author Topic: DIY motorized blinds using Moteino, for $40  (Read 8463 times)
snorp
  • Jr. Member
« on: May 20, 2016, 10:30:13 AM »
I'm using the Moteino to automate my tilt blinds, and posted about it here: http://snorp.net/2016/05/20/blinds-controller.html
Thanks a lot to TomWS, perky, and others on this board who helped me out. I've had a lot of fun, and can't wait to do something else with the Moteino!
snorp
  • Jr. Member
Re: Motorized Blinds
« Reply #1 on: May 20, 2016, 10:39:33 AM »
One thing I don't talk about in that post that folks here might be interested in is a library I created to abstract away much of the boilerplate associated with creating a new "node" -- https://github.com/snorp/Node
Included in this library is a (basic) common message format, automatic waking of sleeping nodes, battery monitoring, and remote node address reassignment.
« Reply #2 on: May 20, 2016, 10:42:13 AM »
Such a nice implementation, I will try to post this on the blog when I find the time.
Thanks very much for sharing it with the forum!
« Reply #3 on: May 20, 2016, 03:04:23 PM »
Good job!  And nice posting!  Well documented, including your learning, EXCELLENT!
BTW, I'm using that motor on a project that I hope to be posting soon (if it works  :D
As I said when you first pointed it out, the Actuator bargain of the Century!
luisr320
  • Sr. Member
  • Country: pt
« Reply #4 on: May 21, 2016, 05:54:25 AM »
Nice project. Thanks for sharing.
« Reply #5 on: May 21, 2016, 07:15:21 AM »
Well done!  :)
Roger2016
« Reply #6 on: October 26, 2016, 09:53:45 AM »
Very nice project!  Thanks for sharing!  If nothing else your link introduced me to the Moteino for which I have a lot of uses.
I'm starting work on this project now for my house.  I have about 10 blinds I want to control all similar to the ones you have.  Do you find those tiny stepper motors have enough grunt to reliably control those blinds?  I was loosing steps on my initial test, but I could have speed and acceleration values incorrect.  Unless I'm missing something and this is probably a dumb newbie question.  I see you have posted a library, but I don't see an .INO file.  How do I use your library?
snorp
  • Jr. Member
« Reply #7 on: October 26, 2016, 01:29:01 PM »
It can't close the blinds as tightly as the manual worm gear mechanism, but I find it does well enough. If I ran across a cheap worm gear actuator that was small enough to fit in a 2" rail, I'd probably give it a try. One thing you could try first is to convert the 28BYJ motors into a bipolar motor. There are some instructions for how to do that here: http://www.jangeox.be/2013/10/change-unipolar-28byj-48-to-bipolar.html. The author there claims about double the torque after this modification.
For my issue (closing the blinds tighter), I don't think it will work, because the 'braking' force of the motor when at rest would not change. The worm gear excels at this by providing a mechanical solution.
I'm using platformio instead of the (shitty) Arduino IDE. Just put the Node and RFM69_WL checkouts into ~/.platformio/lib if you are on Mac/Linux. No idea on Windows, but there will be some documented path for platformio libs to go.
Roger2016
« Reply #8 on: October 26, 2016, 02:34:41 PM »
Thanks Snorp!
I already had the bi-polar conversion on my radar.  We could also add a second motor on the other end of the shaft running synchronized but opposite rotation.  That would double the breaking as well as the torque.  Of course we could add a physical spring loaded brake where we release the brake then rotate the shaft.  The spring will hold the brake a motor or solenoid would release the brake so it would only take power momentarily to release the brake.
snorp
  • Jr. Member
« Reply #9 on: October 26, 2016, 02:39:49 PM »
Thanks Snorp!
All good points! The spring-loaded brake is a good idea. I'm not great with the mechanical bits, so I didn't try anything clever there. I really think a worm gear would solve all of the problems -- more torque, and built-in braking -- but I just haven't run across anything that looks viable. Most of the coupled motor/gear things aren't steppers either so you'd need to have some encoding on the shaft. Not impossible, of course, but adds more complexity.
ramshaklez
Re: DIY motorized blinds using Moteino, for $40
« Reply #10 on: April 08, 2017, 03:32:52 PM »
Looking to use your basic solution to control a motor with a Moteino except rather than opening/closing slats I want to raise/lower the entire blind. I am not sure if I should get a DC motor or a Stepper for this. I realize I'll need a lot of torque.
Also, I am not really sure how to get the motor to automatically stop when the blinds are fully open/closed. Any thoughts are appreciated!!
ChemE
  • Sr. Member
« Reply #11 on: April 08, 2017, 07:39:39 PM »
Limit switches are the standard way to limit the travel/swing of mechanical operators like this.
« Reply #12 on: April 08, 2017, 08:40:41 PM »
Joe Lucid turned me on to this motor:
https://solarbotics.com/product/gm3/
Lots of torque, inexpensive, runs on 3-4V, and, although a bit fast for control applications, can be PWM'd down to 1-2 RPM at the shaft.  It's also relatively quiet.
Easy to drive unipolar if you don't need to reverse direction or with an inexpensive H-Bridge if you do.
  • Country: gb
« Reply #13 on: April 09, 2017, 09:09:02 AM »
Thanks for that link Tom, I've got a project that uses a servo as an actuator requiring a movement of about 13mm with several kg force, I'd have to put end stop switches and an H-bridge but this could reduce the cost by quite a bit ;)
« Reply #14 on: April 09, 2017, 10:24:41 AM »
Perhaps you can identify it by monitoring for a signature change in the current flow.
