Author Topic: Home Automation gateway setup [SOLVED]  (Read 5099 times)
dakine7t9
« on: April 26, 2014, 12:24:03 AM »
I am currently trying to set up my raspberry pi with nginx and have run into a couple of problems. I am not too experienced with this however I have used linux before and know my way around the command line somewhat. I am getting two problems when setting things up. After editing the nginx.conf file and restarting the nginx service I get the following error.
Restarting nginx: nginx: [alert] could not open error log file: open() "/var/log/nginx/error.log" failed (13: Permission denied)
2014/04/25 21:03:15 [warn] 2239#0: the "user" directive makes sense only if the master process runs with super-user privileges, ignored in /etc/nginx/nginx.conf:1
2014/04/25 21:03:15 [emerg] 2239#0: "worker_processes" directive is duplicate in /etc/nginx/nginx.conf:30
nginx.
If I enter
sudo service nginx restart
I get the following:
Restarting nginx: nginx: [emerg] "worker_processes" directive is duplicate in /etc/nginx/nginx.conf:30
nginx.
My second problem occurs when creating the self signed ssl certificate.
I get the error
unknown option –days
to fix this I ended up switching the -days option and -nodes option like this:
sudo openssl req -new -x509 -days 365 -nodes -newkey rsa:2048 -out server.crt -keyout server.key
This seems to work however I have never done any of this so I am not sure if it is correct.
after setting up index.php  and entering my ip in my browser I don't get anything. I'm not sure if its the error in the nginx.conf file causing this but I can't seem to get it working. Any pointers would be greatly appreciated!
« Last Edit: July 25, 2014, 01:50:03 PM by Felix »
hexibot43
  • Jr. Member
Re: Home Automation gateway setup
« Reply #1 on: April 26, 2014, 09:49:35 AM »
Could you post your nginx.conf for us to see?  I want to see everything at least up to line 30 of the file.  I'm sure anyone else that wants to help would be asking the same thing.
dakine7t9
« Reply #2 on: April 26, 2014, 06:30:17 PM »
This is what it looks like (I put line 30 in bold to make it easier to find.)
user  www-data;
worker_processes  2;
events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    #log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
    #                  '$status $body_bytes_sent "$http_referer" '
    #                  '"$http_user_agent" "$http_x_forwarded_for"';
    #access_log  logs/access.log  main;
    sendfile        on;
    #tcp_nopush     on;
    #keepalive_timeout  0;
    keepalive_timeout  65;
    #gzip  on;
    include /etc/nginx/sites-enabled/*;
#user  nobody;
worker_processes  1;
#error_log  logs/error.log;
#error_log  logs/error.log  notice;
#error_log  logs/error.log  info;
#pid        logs/nginx.pid;
events {
http {
    include       mime.types;
    sendfile        on;
    #tcp_nopush     on;
    #gzip  on;
    server {
        listen       80;
        server_name  localhost;
        #charset koi8-r;
        #access_log  logs/host.access.log  main;
        location / {
            root   html;
            index  index.html index.htm;
        #error_page  404              /404.html;
        # redirect server error pages to the static page /50x.html
        error_page   500 502 503 504  /50x.html;
        location = /50x.html {
            root   html;
        # proxy the PHP scripts to Apache listening on 127.0.0.1:80
        #location ~ \.php$ {
        #    proxy_pass   http://127.0.0.1;
        # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
        #    root           html;
        #    fastcgi_pass   127.0.0.1:9000;
        #    fastcgi_index  index.php;
        #    fastcgi_param  SCRIPT_FILENAME  /scripts$fastcgi_script_name;
        #    include        fastcgi_params;
        # deny access to .htaccess files, if Apache's document root
        # concurs with nginx's one
        #location ~ /\.ht {
        #    deny  all;
    # another virtual host using mix of IP-, name-, and port-based configuration
    #server {
    #    listen       8000;
    #    listen       somename:8080;
    #    server_name  somename  alias  another.alias;
    #    location / {
    #        root   html;
    #        index  index.html index.htm;
    # HTTPS server
    #server {
    #    listen       443;
    #    server_name  localhost;
    #    ssl                  on;
    #    ssl_certificate      cert.pem;
    #    ssl_certificate_key  cert.key;
    #    ssl_session_timeout  5m;
    #    ssl_protocols  SSLv2 SSLv3 TLSv1;
    #    ssl_ciphers  HIGH:!aNULL:!MD5;
    #    ssl_prefer_server_ciphers   on;
    #    location / {
    #        root   html;
« Reply #3 on: April 26, 2014, 07:50:29 PM »
I have a working setup published.
See here: https://github.com/LowPowerLab/RaspberryPi-Gateway
ekoelle
« Reply #4 on: July 24, 2014, 01:48:02 AM »
Just started following the blog post to get my home automation gateway setup and I'm running into an error when installing NGINX. I'm a noob when it comes to linux so I'm not sure if I can bypass the rewrite module or not. Safe to do so?
Here's the error I get when running sudo ./configure \:
./configure: error: the HTTP rewrite module requires the PCRE library.
You can either disable the module by using --without-http_rewrite_module
option, or install the PCRE library into the system, or build the PCRE library
statically from the source with nginx by using --with-pcre=<path> option.
Thank you,
Eric
« Reply #5 on: July 24, 2014, 08:07:05 AM »
So you're missing the PCRE stuff, did you run this line?
sudo apt-get install libpcre3 libpcre3-dev libpcrecpp0 libssl-dev zlib1g-dev
ekoelle
« Reply #6 on: July 24, 2014, 11:33:21 AM »
Turns out I misspelled "zlib1g-dev" and didn't realize that the command didn't execute. Re-ran the command and now I'm not getting the PCRE error anymore.
Now I get an error when running "sudo make".
make[1]: *** [objs/src/event/ngx_event_openssl.o] Error 1
make[1]: Leaving directory `/home/pi/sources/nginx-1.4.2'
make: *** [build] Error 2
ekoelle
« Reply #7 on: July 24, 2014, 12:54:56 PM »
A little searching reveals that this is an issue with OpenSSL v1.02 or later. I had to add the following to ngx_event_openssl.c located in nginx/src/event:
#ifndef SSL_OP_MSIE_SSLV2_RSA_PADDING
# define SSL_OP_MSIE_SSLV2_RSA_PADDING 0
#endif
Source1:http://stackoverflow.com/questions/24027327/how-to-install-nginx-from-source-got-ssl-op-msie-sslv2-rsa-padding-error
Source2:http://www.coderexception.com/CmNz3uzbPQWPyXPy/how-to-install-nginx-from-source-got-sslopmsiesslv2rsapadding-error
ekoelle
« Reply #8 on: July 24, 2014, 03:30:27 PM »
Now I have everything for nginx setup and I get the SSL cert prompt and then get the UN/PW prompt however the credentials I entered in .htpasswd aren't working. I've gone through all the steps again and everything seems to be correct yet I can't get past the login credentials.
The only step that doesn't process normally is:
sudo echo -e "USERNAME:`perl -le 'print crypt("PASSWORD","SALT")'`" > sudo /var/www/default/.htpasswd
I get a
-bash: sudo: Permission denied
message so I just run the first part of the command and then copy the un:pw into .htpasswd manually.
Any ideas?
Thank you,
Eric
« Last Edit: July 24, 2014, 03:33:46 PM by ekoelle »
« Reply #9 on: July 24, 2014, 11:04:56 PM »
Hm that should work, if you set everything up the same. You should have credentials USERNAME and PASSWORD.
You should have them in the .htpasswd like this (dummy encrypted password):
USERNAME:SXOa3dKuTTk/.
ekoelle
« Reply #10 on: July 25, 2014, 01:17:06 PM »
Yup, that would work...if I didn't put a space in from of the username. Problem resolved. Thanks for the help Felix.
ekoelle
Re: Home Automation gateway setup [SOLVED]
« Reply #11 on: July 25, 2014, 05:11:24 PM »
And now this while trying to run "npm install serialport":
npm http GET https://registry.npmjs.org/serialport
npm http 304 https://registry.npmjs.org/serialport
npm ERR! Error: EACCES, mkdir '/home/pi/moteino/node_modules'
npm ERR!  { [Error: EACCES, mkdir '/home/pi/moteino/node_modules']
npm ERR!   errno: 3,
npm ERR!   code: 'EACCES',
npm ERR!   path: '/home/pi/moteino/node_modules',
npm ERR!   fstream_type: 'Directory',
npm ERR!   fstream_path: '/home/pi/moteino/node_modules/serialport',
npm ERR!   fstream_class: 'DirWriter',
npm ERR!   fstream_stack:
npm ERR!    [ '/opt/node/lib/node_modules/npm/node_modules/fstream/lib/writer.js:171:23',
npm ERR!      '/opt/node/lib/node_modules/npm/node_modules/mkdirp/index.js:37:53',
npm ERR!      'Object.oncomplete (fs.js:107:15)' ] }
npm ERR!
npm ERR! Please try running this command again as root/Administrator.
npm ERR! System Linux 3.12.22+
npm ERR! command "/opt/node/bin/node" "/opt/node/bin/npm" "install" "serialport"
npm ERR! cwd /home/pi/moteino
npm ERR! node -v v0.10.12
npm ERR! npm -v 1.2.32
npm ERR! path /home/pi/moteino/node_modules
npm ERR! fstream_path /home/pi/moteino/node_modules/serialport
npm ERR! fstream_type Directory
npm ERR! fstream_class DirWriter
npm ERR! code EACCES
npm ERR! errno 3
npm ERR! stack Error: EACCES, mkdir '/home/pi/moteino/node_modules'
npm ERR! fstream_stack /opt/node/lib/node_modules/npm/node_modules/fstream/lib/writer.js:171:23
npm ERR! fstream_stack /opt/node/lib/node_modules/npm/node_modules/mkdirp/index.js:37:53
npm ERR! fstream_stack Object.oncomplete (fs.js:107:15)
npm ERR! Error: EACCES, open 'npm-debug.log'
npm ERR!  { [Error: EACCES, open 'npm-debug.log'] errno: 3, code: 'EACCES', path: 'npm-debug.log' }
npm ERR!
npm ERR! path npm-debug.log
npm ERR! errno 3
npm ERR! stack Error: EACCES, open 'npm-debug.log'
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR!     /home/pi/moteino/npm-debug.log
npm ERR! not ok code 0
« Reply #12 on: July 26, 2014, 10:13:49 AM »
sudo npm install serialport
ekoelle
« Reply #13 on: July 26, 2014, 11:25:19 AM »
pi@KoLo-Automation ~/moteino $ sudo npm install serialport
sudo: npm: command not found
I tried "npm sudo install serialport" also but it just brings up the help screen for the npm command
« Last Edit: July 26, 2014, 11:28:44 AM by ekoelle »
ekoelle
« Reply #14 on: July 28, 2014, 01:33:26 PM »
I was able to get serialport to install using the below command but it doesn't install to the ~/moteino directory.
sudo $(which npm) install -g serialport
Source: http://stackoverflow.com/questions/13964173/npm-install-failing
« Last Edit: July 28, 2014, 01:40:16 PM by ekoelle »
