Here is what you would need to test and compare different sensors to each other. For time being, only BME280 and DS1820's
Addresses for DS's were set once, for that you run first "test" sketch to obtain all addresses on 1wire. Then you copy those into main sketch at the top, where you have DeviceAddress ...
I have two sensors, so
DeviceAddress dsaddr1
DeviceAddress dsaddr2
If you have more, then add more.
Than in void setup() you set resolution with dssetresolution(myds, dsaddr, resolution);
in my case dssetresolution(myds, dsaddr1, resolution);
dssetresolution(myds, dsaddr2, resolution);If you have more sensors, then add more lines.
in void loop() you have dsconvertcommand(myds, dsaddr); and Serial.println(dsreadtemp(myds, dsaddr1, resolution));
Same deal as above, for more sensors, more lines to match
What you should get is something like
Temp (C): 23.87
Temp (C): 23.94
Elapsed time (ms): 1046
Temperature: 24.50 degrees C
Temperature: 76.10 degrees F
Pressure: 961.63 mBar
Altitude: 453.83m
Altitude: 1488.95ft
%RH: 37.43 %
Good stuff. For reference here's the ultimate guide to some of the most common THP sensors (https://www.kandrsmith.org/RJS/Misc/Hygrometers/calib_many.html).
