Author Topic: A simple test sketch to confirm RFM69 is working, using Arduino.  (Read 2385 times)
ragoth
« on: November 28, 2015, 07:08:25 PM »
Hi, I request someone to suggest me a simple sketch to test the 2 way communication of RFM69 using Arduino. I find some sketches but they need Moteino and it is not available in my place.
Sergegsx
  • Jr. Member
  • Country: es
Re: A simple test sketch to confirm RFM69 is working, using Arduino.
« Reply #1 on: November 29, 2015, 02:44:42 AM »
You can use the code from: Node.ino and Gateway.ino
gurari
  • Country: bg
« Reply #2 on: November 29, 2015, 03:04:51 AM »
The Moteino is not so different from any Arduino board in the heart. The main difference is the onboard LED connected to pin 9 (pin 13 on the arduino boards). So simply use a 3.3v arduino board, because the RFM69 is working on 3.3v and connect a Led to pin 9. Then simply load the TxRxBlinky sketch to your arduino following the instructions in the sketch and all should work. When I started a year ago with arduino this was my first radio project. I've used two Arduino Nano  clones working on 5v so I used voltage regulator and voltage deviders.
