3D Printer Sensor Retention Clip for Genie Garage Door Opener
Started by billchurch, April 28, 2014, 09:12:41 AM
billchurch
Instead of taping the sensors, which I did for a while, I whipped up a little retention clip to work on my Genie chain drive.
http://www.thingiverse.com/thing:313518
Hopefully this helps someone else. My opener is a Genie Pro Max 500. I included the Sketchup file so it could be modified to fit whatever.
billchurch
One other note, I used 1/4" cylinder neodymium magnets that I just dropped on one of the chain links as the magnetic source. This has worked well for almost a year without any issues of the magnet jumping or slipping.
Probably the easiest way to get your magnet attached if you have chain drive.
I love the true spirit of sharing and building on an existing OSHW project!
Thanks billchurch for sharing this amazing piece of work that will help those with chain openers!
