waiting for socket connection
Started by vk3jap, April 21, 2018, 08:02:40 AM
vk3jap
This famous old issue is causing me grief now...
I have tried the release Felix suggested, and the Jessie image.. and now the latest (and updated) one from official rPi respository - RASPBIAN.
I m all out of luck and feeling very low here.. someone please help. :-)
sparky
#1
I had the same issue when installing the latst version, 8.10, using the script.  I ended up installing by;
•Copy the contents of this directory in  /home/pi/gateway
•run  npm install  in the  /home/pi/gateway  directory to install all node dependencies
•Adjust any email/password/SMS settings in  settings.json5
and then it worked.  But then I was having some other strange issues which Felix couldn't figure out at that time.  I went back to 8.9
Good luck
AFAIK the latest raspbian release works with the scripts. There was a small change in the install script a few weeks ago related to php, make sure to get that change (download the latest head of the repository).
vk3jap
I'm trying everything... to get this working. Different versions of pi images. pi bakery. Jessie.. etc etc. I'm just getting no where.
This is such an awesome project but this part is letting it down :-( :-(
I have rPi3B
Could someone please take out their personal passwords etc and post up a full flash .IMG which works..? ie had the rPi OS and the Gateway software installed/configured. I'm running ttyS0 at 19200 but I know how to change that easily.
Pleeeeaaaase  :-[ :-[ :-[    (i'll happily pay some BitCoin to anyone for helping ou there, I had grand plans with Moteino)
vk3jap
I've tried that Felix...no good.
So that we are talking the same could you please post links.?
Pi image :
Should I run update/upgrade?
Gateway code :
Follow steps for gateway code from :
LukaQ
ttyS0 won't work with pi3, /dev/serial0 should be it
I see you have a lot of trouble... why don't you get older image that worked, like from 2y ago, and get it running... then run script. Before that you change serial port. Don't do more things at one, just one. Install Os, the lite one I think I have. change serial, check that you get something on serial. Install GW
I have a guide for the software here: https://lowpowerlab.com/guide/gateway/setup-software/
Once your Pi is setup and internet connected you can follow the steps at that link.
Get the lite-image from here: https://www.raspberrypi.org/downloads/raspbian/
(unless you have a specific reason to get the desktop version)
The gateway setup runs upgrade for you.
The example sketch on your Moteino at the gateway is here: https://github.com/LowPowerLab/RFM69/blob/master/Examples/PiGateway/PiGateway.ino
vk3jap,
I would like to help getting the setup script working.
Let me know if you still have trouble. Let's try to keep this in 1 thread.
vk3jap
Thanks Felix. I've done most (I think all) of those steps but perhaps not exactly in the order/combination you're suggesting so will follow your advice word for word and see how I go.
On the side of the sending nodes...what would you suggest for the simplest sending node setup such that it tests the whole thing end to end. Ie the rPi, the Moteino connected to that AND the Moteino which is sending. Re the sending side, I am using one which is a LED and LDR suggested from Tom's guide but it requires mods to your confirmation to be a supported device. What would be your simplest, already supported, sending device. Ie just a bare bones Mote with say a simple on off LED.. that DOESN'T need any extra config to be supported.
On the greater subject..  Given how much time I've spent on it..have you considered selling a complete 3 pack set which is tested. rPi(3B), RX Mote, Tx Mote with SD flash and SW(2 X .ino) ..all tested and working. I'd pay for this.! All the end user would need to do is change wireless details etc then add their other projects in. If they had any issues, could easily revert back to know working configuration.
#9
I just tested the setup on a Pi3 (older Pi3) with the latest raspbian-sketch-lite (4-18-2018 release).
I followed these exact steps: https://lowpowerlab.com/guide/gateway/setup-software/
Everything works. Attached is the setup log output from the console.
Upon accessing the pi on the network, it prompts the credentials and then it shows the empty node list as expected. No problems. Next step is to configure the serial port. By default it is the GPIO serial at 19200 baud. This matches the settings in the PiGateway sketch.
Then you can use a remote moteino loaded with the RandomNumbers sketch that would simply send data which you can immediately see and look at nice graphs etc. This works guaranteed as long as you do your part and match the sketch settings with the radio hardware.
Thanks for the package suggestion - i have given it some on-off thought but it would require a lot of time on my part to setup and test everything for such a package. The cost would be very high, things could still not work at the user's end, and very few folks if anyone would buy this. I could maybe do this on a hourly basis for a specific setup. But too busy now.
vk3jap
#10
Hey Felix..
ok, tried all those. Still no go. The issue now seems to be the serial port - ie which one do I use with this image.?  see output from DMSEG below.
- I am using the image here : https://downloads.raspberrypi.org/raspbian_lite_latest
- using your gateway.ino and random numbers.ino
- no longer getting errors on waiting for socket etc - that seems resolved. issue now seems to be no data on serial.
what serial port should I use..? I installed minicom but and not seeing anything from the serial port.
Code headers below. I'm on 433Mhz with the highPower TX modules.
Here is the serial output from the Gateway Mote.. serial in the arduino IDE. That seems to indicate that the random numbers mote is working - it is node 98. that would prove all the .INO code to be correct.
The serial output from the Mote to the rPi has worked before.. as I was getting nodes come up (changing node ID's, the original issue) .. everythign is the same, wiring wise.
Think my issue at this point is which serial do I use..? what is AMA0 - what does AMA mean.?
I went for the serial connection between Mote and rPi because I though it was simpler, less drivers and points of failure.. should I order the USB mote..???
::Serial from Gateway Mote ::
QuoteTransmitting at 433 Mhz...
SPI Flash Init OK!
[98] F:41.5   [RSSI:-33][ACK-sent]
[98] F:42.5   [RSSI:-33][ACK-sent]
[98] F:70.5   [RSSI:-33][ACK-sent]
[98] F:2.5   [RSSI:-33][ACK-sent]
[98] F:-66.5   [RSSI:-33][ACK-sent]
[98] F:-11.5   [RSSI:-31][ACK-sent]
[98] F:-92.5   [RSSI:-33][ACK-sent]
[98] F:64.5   [RSSI:-33][ACK-sent]
TX node...:
Quote#define NODEID         98    //unique for each node on same network
#define NETWORKID     200  //the same on all nodes that talk to each other
#define GATEWAYID     1
//Match frequency to the hardware version of the radio on your Moteino (uncomment one):
#define FREQUENCY     RF69_433MHZ
//#define FREQUENCY     RF69_915MHZ
#define IS_RFM69HW_HCW  //uncomment only for RFM69HW/HCW! Leave out if you have RFM69W/CW!
Gatway Node..:
Quote#define NODEID          1 //the ID of this node
#define NETWORKID     200 //the network ID of all nodes this node listens/talks to
#define FREQUENCY     RF69_433MHZ //Match this with the version of your Moteino! (others: RF69_433MHZ, RF69_868MHZ)
#define ENCRYPTKEY    "sampleEncryptKey" //identical 16 characters/bytes on all nodes, not more not less!
#define ACK_TIME       30  // # of ms to wait for an ack packet
#define ENABLE_ATC    //comment out this line to disable AUTO TRANSMISSION CONTROL
#define ATC_RSSI      -75  //target RSSI for RFM69_ATC (recommended > -80)
// Serial baud rate must match your Pi/host computer serial port baud rate!
#define SERIAL_EN     //comment out if you don't want any serial verbose output
#define SERIAL_BAUD  19200
Quotepi@raspberrypi:~ $ cd /dev
pi@raspberrypi:/dev $ ls tty*
tty   tty10  tty13  tty16  tty19  tty21  tty24  tty27  tty3   tty32  tty35  tty38  tty40  tty43  tty46  tty49  tty51  tty54  tty57  tty6   tty62  tty8     ttyprintk
tty0  tty11  tty14  tty17  tty2   tty22  tty25  tty28  tty30  tty33  tty36  tty39  tty41  tty44  tty47  tty5   tty52  tty55  tty58  tty60  tty63  tty9
tty1  tty12  tty15  tty18  tty20  tty23  tty26  tty29  tty31  tty34  tty37  tty4   tty42  tty45  tty48  tty50  tty53  tty56  tty59  tty61  tty7   ttyAMA0
Quotepi@raspberrypi:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.34-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1110 SMP Mon Apr 16 15:18:51 BST 2018
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] cma: Reserved 8 MiB at 0x3ac00000
[    0.000000] On node 0 totalpages: 242688
[    0.000000] free_area_init_node: node 0, pgdat 80c84e40, node_mem_map ba3a1000
[    0.000000]   Normal zone: 2133 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 242688 pages, LIFO batch:31
[    0.000000] random: fast init done
[    0.000000] percpu: Embedded 17 pages/cpu @ba34a000 s38720 r8192 d22720 u69632
[    0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
  • 0
  • 1
  • 2
  • 3
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
    [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=768 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=37064e22-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 940236K/970752K available (7168K kernel code, 575K rwdata, 2072K rodata, 1024K init, 706K bss, 22324K reserved, 8192K cma-reserved)
    [    0.000000] Virtual kernel memory layout:
                       vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                       fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                       vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                       lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                       modules : 0x7f000000 - 0x80000000   (  16 MB)
                         .text : 0x80008000 - 0x80800000   (8160 kB)
                         .init : 0x80b00000 - 0x80c00000   (1024 kB)
                         .data : 0x80c00000 - 0x80c8fd4c   ( 576 kB)
                          .bss : 0x80c96f4c - 0x80d478b4   ( 707 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] ftrace: allocating 25231 entries in 74 pages
    [    0.000000] Hierarchical RCU implementation.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    [    0.000023] Switching to timer-based delay loop, resolution 52ns
    [    0.000276] Console: colour dummy device 80x30
    [    0.000817] console [tty1] enabled
    [    0.000854] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    [    0.000894] pid_max: default: 32768 minimum: 301
    [    0.001220] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001253] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.002208] Disabling memory control group subsystem
    [    0.002307] CPU: Testing write buffer coherency: ok
    [    0.002716] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.003108] Setting up static identity map for 0x100000 - 0x10003c
    [    0.003241] Hierarchical SRCU implementation.
    [    0.003891] smp: Bringing up secondary CPUs ...
    [    0.004591] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.005336] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.006066] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.006169] smp: Brought up 1 node, 4 CPUs
    [    0.006239] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    [    0.006261] CPU: All CPU(s) started in HYP mode.
    [    0.006278] CPU: Virtualization extensions available.
    [    0.007147] devtmpfs: initialized
    [    0.017490] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    [    0.017742] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.017787] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.018366] pinctrl core: initialized pinctrl subsystem
    [    0.019127] NET: Registered protocol family 16
    [    0.021678] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.026341] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.026373] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.026592] Serial: AMBA PL011 UART driver
    [    0.028226] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    [    0.028702] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
    [    0.059653] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dmachans=0x1
    [    0.061199] SCSI subsystem initialized
    [    0.061438] usbcore: registered new interface driver usbfs
    [    0.061507] usbcore: registered new interface driver hub
    [    0.061607] usbcore: registered new device driver usb
    [    0.070076] raspberrypi-firmware soc:firmware: Attached to firmware from 2018-04-16 18:16
    [    0.071360] clocksource: Switched to clocksource arch_sys_counter
    [    0.148763] VFS: Disk quotas dquot_6.6.0
    [    0.148876] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.149080] FS-Cache: Loaded
    [    0.149290] CacheFiles: Loaded
    [    0.158128] NET: Registered protocol family 2
    [    0.158868] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.158999] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.159201] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.159347] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.159409] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.159653] NET: Registered protocol family 1
    [    0.160105] RPC: Registered named UNIX socket transport module.
    [    0.160129] RPC: Registered udp transport module.
    [    0.160148] RPC: Registered tcp transport module.
    [    0.160167] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.161642] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    [    0.164415] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [    0.172350] FS-Cache: Netfs 'nfs' registered for caching
    [    0.172960] NFS: Registering the id_resolver key type
    [    0.173007] Key type id_resolver registered
    [    0.173026] Key type id_legacy registered
    [    0.173055] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.174925] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
    [    0.175071] io scheduler noop registered
    [    0.175093] io scheduler deadline registered (default)
    [    0.175386] io scheduler cfq registered
    [    0.175407] io scheduler mq-deadline registered
    [    0.175427] io scheduler kyber registered
    [    0.178119] BCM2708FB: allocated DMA memory fad10000
    [    0.178165] BCM2708FB: allocated DMA channel 0 @ bb813000
    [    0.205843] Console: switching to colour frame buffer device 160x48
    [    0.223211] bcm2835-rng 3f104000.rng: hwrng registered
    [    0.223490] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [    0.224182] vc-sm: Videocore shared memory driver
    [    0.224583] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    [    0.234345] brd: module loaded
    [    0.243163] loop: module loaded
    [    0.243295] Loading iSCSI transport class v2.0-870.
    [    0.244064] libphy: Fixed MDIO Bus: probed
    [    0.244282] usbcore: registered new interface driver lan78xx
    [    0.244495] usbcore: registered new interface driver smsc95xx
    [    0.244669] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    0.472921] Core Release: 2.80a
    [    0.473027] Setting default values for core params
    [    0.478046] Finished setting default values for core params
    [    0.683327] Using Buffer DMA mode
    [    0.688258] Periodic Transfer Interrupt Enhancement - disabled
    [    0.693249] Multiprocessor Interrupt Enhancement - disabled
    [    0.698217] OTG VER PARAM: 0, OTG VER FLAG: 0
    [    0.703145] Dedicated Tx FIFOs mode
    [    0.708350] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad04000 dma = 0xfad04000 len=9024
    [    0.713505] FIQ FSM acceleration enabled for :
                   Non-periodic Split Transactions
                   Periodic Split Transactions
                   High-Speed Isochronous Endpoints
                   Interrupt/Control Split Transaction hack enabled
    [    0.738885] dwc_otg: Microframe scheduler enabled
    [    0.738942] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805e6a40
    [    0.744013] WARN::hcd_init_fiq:460: FIQ ASM at 0x805e6da8 length 36
    [    0.749010] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87e000
    [    0.753989] dwc_otg 3f980000.usb: DWC OTG Controller
    [    0.758950] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    [    0.763991] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
    [    0.769042] Init: Port Power? op_state=1
    [    0.774008] Init: Power Port (0)
    [    0.779051] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    0.783996] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    0.788931] usb usb1: Product: DWC OTG Controller
    [    0.793881] usb usb1: Manufacturer: Linux 4.14.34-v7+ dwc_otg_hcd
    [    0.798889] usb usb1: SerialNumber: 3f980000.usb
    [    0.804515] hub 1-0:1.0: USB hub found
    [    0.809566] hub 1-0:1.0: 1 port detected
    [    0.815089] dwc_otg: FIQ enabled
    [    0.815094] dwc_otg: NAK holdoff enabled
    [    0.815099] dwc_otg: FIQ split-transaction FSM enabled
    [    0.815109] Module dwc_common_port init
    [    0.815350] usbcore: registered new interface driver usb-storage
    [    0.820605] mousedev: PS/2 mouse device common for all mice
    [    0.825761] IR NEC protocol handler initialized
    [    0.830781] IR RC5(x/sz) protocol handler initialized
    [    0.835742] IR RC6 protocol handler initialized
    [    0.840604] IR JVC protocol handler initialized
    [    0.845344] IR Sony protocol handler initialized
    [    0.850000] IR SANYO protocol handler initialized
    [    0.854683] IR Sharp protocol handler initialized
    [    0.859300] IR MCE Keyboard/mouse protocol handler initialized
    [    0.863983] IR XMP protocol handler initialized
    [    0.869301] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
    [    0.874388] bcm2835-cpufreq: min=600000 max=1200000
    [    0.879514] sdhci: Secure Digital Host Controller Interface driver
    [    0.884356] sdhci: Copyright(c) Pierre Ossman
    [    0.889494] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
    [    0.894709] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
    [    0.899713] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.906049] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.911140] hidraw: raw HID events driver (C) Jiri Kosina
    [    0.916225] usbcore: registered new interface driver usbhid
    [    0.921160] usbhid: USB HID core driver
    [    0.926676] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
    [    0.932915] [vc_sm_connected_init]: start
    [    0.942948] [vc_sm_connected_init]: end - returning 0
    [    0.948323] Initializing XFRM netlink socket
    [    0.953165] NET: Registered protocol family 17
    [    0.958047] Key type dns_resolver registered
    [    0.963191] Registering SWP/SWPB emulation handler
    [    0.968556] registered taskstats version 1
    [    0.979098] uart-pl011 3f201000.serial: cts_event_workaround enabled
    [    0.984099] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
    [    0.990941] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
    [    0.995972] mmc-bcm2835 3f300000.mmc: DMA channel allocated
    [    1.031475] Indeed it is in host mode hprt0 = 00021501
    [    1.097287] sdhost: log_buf @ bad07000 (fad07000)
    [    1.139874] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    1.146426] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.152863] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    1.160445] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    1.181406] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    [    1.187129] of_cfs_init
    [    1.191971] of_cfs_init: OK
    [    1.197070] Waiting for root device PARTUUID=37064e22-02...
    [    1.241395] usb 1-1: new high-speed USB device number 2 using dwc_otg
    [    1.246259] Indeed it is in host mode hprt0 = 00001101
    [    1.318561] mmc0: host does not support reading read-only switch, assuming write-enable
    [    1.326216] mmc0: new high speed SDHC card at address 59b4
    [    1.331877] mmcblk0: mmc0:59b4 USD   15.0 GiB
    [    1.338363]  mmcblk0: p1 p2
    [    1.377215] mmc1: new high speed SDIO card at address 0001
    [    1.392650] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.397872] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    1.412010] devtmpfs: mounted
    [    1.420093] Freeing unused kernel memory: 1024K
    [    1.481637] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
    [    1.486808] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    1.492673] hub 1-1:1.0: USB hub found
    [    1.497861] hub 1-1:1.0: 5 ports detected
    [    1.821415] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    [    1.948473] systemd[1]: System time before build time, advancing clock.
    [    1.961693] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
    [    1.966821] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    1.974588] smsc95xx v1.0.6
    [    2.074675] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:3b:6c:59
    [    2.100624] NET: Registered protocol family 10
    [    2.107281] Segment Routing with IPv6
    [    2.122897] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    2.167393] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
    [    2.179627] systemd[1]: Detected architecture arm.
    [    2.181419] usb 1-1.4: new full-speed USB device number 4 using dwc_otg
    [    2.211581] systemd[1]: Set hostname to <raspberrypi>.
    [    2.316397] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c52f
    [    2.322271] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [    2.328112] usb 1-1.4: Product: USB Receiver
    [    2.333984] usb 1-1.4: Manufacturer: Logitech
    [    2.346192] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C52F.0001/input/input0
    [    2.353469] hid-generic 0003:046D:C52F.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3f980000.usb-1.4/input0
    [    2.364918] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:046D:C52F.0002/input/input1
    [    2.441940] hid-generic 0003:046D:C52F.0002: input,hiddev96,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.4/input1
    [    2.541445] usb 1-1.5: new high-speed USB device number 5 using dwc_otg
    [    2.679975] usb 1-1.5: New USB device found, idVendor=05ac, idProduct=1006
    [    2.687081] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    2.694127] usb 1-1.5: Product: Keyboard Hub
    [    2.701056] usb 1-1.5: Manufacturer: Apple, Inc.
    [    2.707933] usb 1-1.5: SerialNumber: 000000000000
    [    2.715412] hub 1-1.5:1.0: USB hub found
    [    2.722251] hub 1-1.5:1.0: 3 ports detected
    [    2.802415] systemd[1]: Listening on udev Control Socket.
    [    2.817636] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
    [    2.832672] systemd[1]: Created slice User and Session Slice.
    [    2.847540] systemd[1]: Created slice System Slice.
    [    2.862543] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [    2.877865] systemd[1]: Listening on Syslog Socket.
    [    2.892393] systemd[1]: Reached target Slices.
    [    3.041520] usb 1-1.5.2: new low-speed USB device number 6 using dwc_otg
    [    3.200989] usb 1-1.5.2: New USB device found, idVendor=05ac, idProduct=0220
    [    3.207047] usb 1-1.5.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [    3.207056] usb 1-1.5.2: Product: Apple Keyboard
    [    3.207063] usb 1-1.5.2: Manufacturer: Apple, Inc
    [    3.518196] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    3.623838] systemd-journald[111]: Received request to flush runtime journal from PID 1
    [    3.842919] input: Apple, Inc Apple Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.2/1-1.5.2:1.0/0003:05AC:0220.0003/input/input2
    [    3.914595] apple 0003:05AC:0220.0003: input,hidraw2: USB HID v1.11 Keyboard [Apple, Inc Apple Keyboard] on usb-3f980000.usb-1.5.2/input0
    [    3.915810] input: Apple, Inc Apple Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5.2/1-1.5.2:1.1/0003:05AC:0220.0004/input/input3
    [    3.981977] apple 0003:05AC:0220.0004: input,hidraw3: USB HID v1.11 Device [Apple, Inc Apple Keyboard] on usb-3f980000.usb-1.5.2/input1
    [    4.245695] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.248654] bcm2835_alsa bcm2835_alsa: card created with 8 channels
    [    4.390918] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
    [    4.401978] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
    [    4.402265] usbcore: registered new interface driver brcmfmac
    [    4.631489] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
    [    4.633196] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
    [    4.837417] random: crng init done
    [    5.578338] uart-pl011 3f201000.serial: no DMA platform data
    [    6.085965] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
    [    6.116205] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [    6.116271] brcmfmac: power management disabled
    [    6.583647] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
    [    6.584005] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [    7.355471] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [   10.079745] Bluetooth: Core ver 2.22
    [   10.079825] NET: Registered protocol family 31
    [   10.079831] Bluetooth: HCI device and connection manager initialized
    [   10.079855] Bluetooth: HCI socket layer initialized
    [   10.079868] Bluetooth: L2CAP socket layer initialized
    [   10.079902] Bluetooth: SCO socket layer initialized
    [   10.091620] Bluetooth: HCI UART driver ver 2.3
    [   10.091634] Bluetooth: HCI UART protocol H4 registered
    [   10.091640] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   10.091855] Bluetooth: HCI UART protocol Broadcom registered
    [   10.257342] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   10.257380] Bluetooth: BNEP filters: protocol multicast
    [   10.257401] Bluetooth: BNEP socket layer initialized
    pi@raspberrypi:~ $
vk3jap
maybe this lite image doesn't have the drivers etc for the GPIO serial..?
Quotepi@raspberrypi:~ $ dmesg | grep serial
[    0.028788] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.979109] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    0.984098] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[    5.827925] uart-pl011 3f201000.serial: no DMA platform data
pi@raspberrypi:~ $
Quotepi@raspberrypi:/dev $ ls -l ser*
lrwxrwxrwx 1 root root 7 Apr 27 09:17 serial1 -> ttyAMA0
LukaQ
Why don't you go with older image, jessie, run the script and be done with it?
Unless you are doing something else wrong, this should be very easy, step by step thing to do
vk3jap
I've tried that already, a while back now. I've tried everything.
I'm going with what Felix is suggesting.
vk3jap
Quote from: LukaQ on April 27, 2018, 05:23:00 AM
Are you using the more via serial or USB..?
