Upgrading NodeJS causes gateway.js errors
Started by TrickyT, September 23, 2022, 05:39:20 PM
TrickyT
I upgraded Node to v18.9.0 because another application I run required this version. But now gateway gets the following error:
/home/tef/gateway/gateway.js:834
          if (metricsDef.metrics[metric].regexp.test(match[0]))
TypeError: metricsDef.metrics[metric].regexp.test is not a function
    at /home/tef/gateway/gateway.js:834:49
    at newArguments.<computed> (/home/tef/gateway/node_modules/nedb/lib/executor.js:29:17)
    at Cursor.execFn (/home/tef/gateway/node_modules/nedb/lib/datastore.js:518:14)
    at callback (/home/tef/gateway/node_modules/nedb/lib/cursor.js:126:19)
    at /home/tef/gateway/node_modules/nedb/lib/cursor.js:193:12
    at /home/tef/gateway/node_modules/nedb/lib/datastore.js:329:14
    at async.eachSeries (/home/tef/gateway/node_modules/nedb/node_modules/async/lib/async.js:130:20)
    at /home/tef/gateway/node_modules/nedb/lib/datastore.js:323:11
    at fn (/home/tef/gateway/node_modules/nedb/node_modules/async/lib/async.js:582:34)
    at Immediate.<anonymous> (/home/tef/gateway/node_modules/nedb/node_modules/async/lib/async.js:498:34)
Node.js v18.9.0
I'm a javascript noob, but I did google around a bit and it seems like metricsDef.metrics[metric] needs to be a regular expression.
There are several places in gateway.js where syntax like this is used, but in one place where the if() is failing metricsDef.metrics[metric] is set to "{ name: 'DEBUG', regexp: {}, value: ' ' }" and match[0] equals the string "F:99.21". Can someone please suggest changes to gateway.js to fix this problem.
(EDIT: fix typo)
Did you just update node? How about node js and reinstall the packages used by the gateway app?
There is a guide here for that:
https://lowpowerlab.com/guide/gateway/node-npm-updates/
Let me know if this helps.
TrickyT
I followed the NodeJS & npm update guide. That seemed to go just fine and created a new directory of node_modules. Unfortunately gateway.js encounters exactly the same error as I described previously.
There is nothing wrong with gateway.js.
It is the metric that is not correct, as you can see in the core.js metrics file, the DEBUG metric does have a valid regex. Please check your metrics files against this.
TrickyT
OK, will do. Thanks for the tip. I haven't modified any of my metrics files in well over a year, so perhaps the new version of node js uses a more strict interpretation of some language feature. Will report back after I figure it out.
TrickyT
The metrics definitions are all fine. The DEBUG metric does have a valid regexp defined in the core.js module, but after this module is loaded and merge() is called, javascript no longer knows it's a regexp. If I call "console.log(metricsDef.metrics[metric].regexp.toString());" for every metric in core.js and _LowPowerLab/*.js and my local metric definitions, what gets logged to the console every time is "[object Object]" while all the other properties like "name" and "value" display what is expected. What should be getting logged is a string containing the regular expression. The runtime error getting logged when gateway tries to find a matching metric...
    TypeError: metricsDef.metrics.regexp.test is not a function
is because javascript doesn't know the object is a regexp and doesn't think the object has a test() method.
TrickyT
#6
Here's a test program to illustrate the problem:
var merge = require('merge');
var tmp = require('./metrics/core.js');
global.metricsDef = {};
metricsDef.metrics = merge(true, metricsDef.metrics, tmp.metrics);
for(var metric in metricsDef.metrics)
  console.log('metric: ' + metricsDef.metrics[metric].name);
...which produces the following...
metric: DEBUG
[object Object]
metric: V
[object Object]
metric: RSSI
[object Object]
metric: TXLVL
[object Object]
metric: START
[object Object]
metric: TYPE
[object Object]
metric: P_TXP
[object Object]
EDIT: I know the metric definitions in core.js are read in correctly. It's the merge() that's failing.
TrickyT
OK, my issue has been resolved.
When I used npm to re-install all the javascript packages, it chose a newer implementation of the merge module. Newer (broken) version 2.1.1, older (working) version 1.2.1. Both come from https://github.com/yeikos/js.merge. I re-installed the older version from a backup and gateway is working again.
This is a known issue in version 2.1.1 (https://github.com/yeikos/js.merge/issues/41) that was opened in March, 2021 and has not been closed. So anyone else upgrading their javascript packages needs to be aware of this issue.
Thanks for the update, it's good to know.
However I noticed the comments in this commit that I submitted a while ago.
There was a change to gateway.js that involves calling merge with a false first parameter: merge(false, ...)
Did you get latest gateway.js? That should have fixed your problem even with merge 2.1.1
