Software support => Pi Gateway => Topic started by: walti82w on October 20, 2015, 06:49:52 AM
Title: Temperature Value to send to moteino
Post by: walti82w on October 20, 2015, 06:49:52 AM
I need someone to point me into the right direction. The system works great for me so far. I am used to the moteinos.
But I am a total newbie in pi / javascript.
I do like to send temperature-set values to the moteino from the web interface. So basically I need a input-control for the value.
Is that possible..? A little roadmap would help me I guess...
Thank you in advance!
walti
Title: Re: Temperature Value to send to moteino
Post by: Felix on October 20, 2015, 08:23:16 AM
walti,
What is your web interface? Are you using my Moteino Gateway (http://lowpowerlab.com/gateway) solution?
That has a simple dialog that you can use to send a remote Moteino (that is in listen mode) any message, manually.
Post by: walti82w on October 20, 2015, 08:40:38 AM
Thank you for your attention! Yes I am using your interface. (great work by the way)
Ok. So there is no solution yet for adding a slider or something.
walti
Post by: Felix on October 20, 2015, 08:58:45 AM
No sliders :(
But you can add your own widgets ;)
Post by: walti82w on October 20, 2015, 09:34:56 AM
Thank you!  8)
