SwitchMote Kit - features
Started by cndesu, January 08, 2017, 08:53:39 AM
cndesu
Does this switch mote will perform functions or even measure the current flow?
I want to use this for my curtain project. I do not want to know how to start. I have already the motorized curtains and wanted to control them remotely and also locally. I found this option much easier and want to control two curtains open close. With three buttons I am scratching my head if this is possible?
This kit does not monitor current/watts, does not dim.
It only turns ON/OFF relays which can feed any AC load you want - lights, motors, curtains etc.
The 3 buttons allow you to do anything you want, in the sample sketch they turn ON the relay(s) and notify the gateway they were pushed - and also if the SwitchMote is "SYNC-ed" with another SwitchMote then it notifies that other SM that a button was pressed etc.
