Restore a deleted node?
Started by wile1411, October 29, 2018, 08:02:59 AM
wile1411
I deleted a node from the web interface using the 'X' at the top right.
Is there a way to get the node to reappear? I've had data still being sent, but it's just the RSSI at the moment.
sparky
#1
Hey Wile,
Depending on the node you deleted, if it polls it should automatically pop back up.  If you have something like a SwitchMote or GarageMote, pushing a button or opening the garage door will pop the node back up.
sparky is correct.
Any data from any node on the RF network, will generate a new UI node automatically and add any recognized metrics (as defined in metrics.js) to that node. RSSI is automatically logged regardless, if you are using the correct RFM69 PiGateway example sketch.
Also note that the settings page has a keepMetricLogsOnDelete setting, if that is false, whenever you delete a node, it also deletes any logged data for that node, otherwise it keeps the data and only deletes the node from the UI.
