Problem printing out logged event time
Started by Nspector5, September 16, 2016, 01:02:35 PM
Nspector5
I am currently monitoring the daily high and low temperature and logging the time when a new high or low is reached. Twice a day, I will tweet out the daily high or overnight low. I am currently having a problem saving, and then outputting the date information. My setup is as follows:
Variables in metric.js:
var dailyhightemp = 0;
var dailyhightime = new Date();
var dailylowtemp = 100;
var dailylowtime = new Date();
Function to monitor the temperature:
MonitorOvernightLow : { label:'Monitor Overnight Low', icon:'fa-heartbeat', descr:'Monitor the overnight low temperature',
	if (node.metrics['Outside'] && node.metrics['Outside'].value < dailylowtemp && (Date.now() - new Date(node.metrics['Outside'].updated).getTime() < 2000))
		dailylowtemp = node.metrics['Outside'].value;
		dailylowtime = Date.now();
		console.log('New Daily Low set:'+dailylowtemp+'');
And the function to tweet the temperature:
TweetOvernightLow : { label:'Tweet Overnight Low', icon:'alert', descr:'Send tweet of the overnight low temperature',
	nextSchedule:function(node) { return exports.timeoutOffset(8,0); }, //ie 8:00 (8am)
        scheduledExecute:function(node) {
	 sendTweet('It got down to'+dailylowtemp+'deg @ ' + (dailylowtime.toLocaleTimeString() + (dailylowtime.getHours() > 12 ? 'PM':'AM')));
	dailylowtemp = 100;
The problem comes in that the
section, in that I get an error stating that dailylowtime does not have toLocaleTimeString().
Any ideas on how to resolve this?
Also, I'd like to combine the monitor and sendtweet functions, but I have not figured out how to do that either.
Thank you.
Your dailylowtime.toLocaleTimeString() won't work because the scope of the declared variable is not what you probably assume. So when your code executes dailylowtime is null instead of a date object.
Although the metrics.js is a separate file, the scope is that from gateway.js since that is where the events are scheduled. So a band aid fix might be to move the declarations in gateway.js but I haven't verified this. I would not rely on global vars for what you want to do. Also scheduled events encapsulate the scope they were declared in. So an event 1 hour later will have the scope of when it was scheduled, so it could be stale. For this reason I would always "get-latest" of whatever you are trying to check. If you want to save variables there's a good example here on how to do that in an event.
You could combine these but you have to decide how/when you want your hi/low values to be determined. Right now you have an event that fires on every message (the one using serverExecute) and you are trying to set min/max variables in metrics.js (although this won't work as you have it now - see above link for saving those values in the neDB node database instead which would keep them safe in case of a crash). The other uses scheduledExecute to run twice daily and just tweet the saved values.
To combine the two you could write a custom function somewhere to determine the daily hi/low from the past day worth of data, then just call that in your MonitorOvernightLow.
The node metric logs are handled by functions in logutil.js, take a look in there to see how you might do that. But I would just save the values in the db, then you only need the scheduled event to read and tweet them.
