Author Topic: PiGateway v9.1.0 Released  (Read 36911 times)
« on: April 19, 2020, 09:45:11 PM »
The CHANGELOG is in this blog post.
This thread can serve as discussion, bug reporting, and help with upgrading to this release.
sparky
  • Sr. Member
Re: PiGateway v9.1.0 Released
« Reply #1 on: April 22, 2020, 08:19:06 PM »
IP for thermostat no longer in settings?  Or am I missing something
« Reply #2 on: April 24, 2020, 09:28:42 AM »
You're right, first bug is in!
I somehow dropped that when I merged the diffs for the settings file, and I had it on my Gateway unchanged so I totally missed it in testing.
I posted a commit and if you install the latest code it will pick it up otherwise you can add that section to your settings.json5 file.
Thanks!!
sparky
  • Sr. Member
« Reply #3 on: April 24, 2020, 10:58:17 AM »
Thanks Felix!
Also;
* Have you personally used or tested the "Garage: Auto CLOSE" metric you have in the example folder?  I haven't been able to get it to work.
* On the UI drop down, Gateway Uptime and Freq. show unknown.. where is it grabbing this information from?
Thanks for all the great work!
« Last Edit: April 24, 2020, 03:07:59 PM by sparky »
« Reply #4 on: April 24, 2020, 03:21:59 PM »
It was contributed and I haven't used it. Hence no interest or time to debug it. I would welcome help fixing bugs though!
Those come from the sketch running on the RF Gateway. You will need to update your RF Gateway sketch as mentioned in the blog release.
sparky
  • Sr. Member
« Reply #5 on: April 24, 2020, 03:41:35 PM »
I'll keep trying
Menu after updating PiGateway sketch attached
« Last Edit: April 24, 2020, 05:55:39 PM by sparky »
ssmall
  • Full Member
« Reply #6 on: April 25, 2020, 10:54:35 AM »
With regard to Garage: Auto CLOSE not working with PiGateway V9.x.x, I believe the reason for this is that the node is updated in the event and saved to the database.  However the function
global.runAndReschedule = function(functionToExecute, node, eventKey) which invokes the event calls
global.schedule = function(node, eventKey).  This function updates the executeDateTime on the node.  It then retrieves the node from the database sets the event on the retrieved node and saves the node back to the database.  I believe it is here that the data that was written by the Garage: Auto CLOSE is overwritten by global.schedule causing the metric to not work properly.
@Felix, I am open to suggestions as to how to fix the issue.  It looks like it would involve reworking how scheduled events work.
Hope that makes sense,
-Steve
sparky
  • Sr. Member
« Reply #7 on: April 25, 2020, 01:58:05 PM »
@ssmall
Thanks for the info.
HeneryH
  • Full Member
« Reply #8 on: April 25, 2020, 03:50:16 PM »
Anyone have any experience with this
npm-request replaced with native node http module – this is to handle any http requests (like for the CT50 Thermostat)
Can this be used for sending http posts to the gateway to initiate events?
« Reply #9 on: April 26, 2020, 06:32:04 PM »
@sparky, does your sketch send an UPTIME message response? (Ie if you type UPTIME in terminal)
Both the sketch is made to send that, and the gateway to ask for it, when they restart.
@ssmall, a PR with the fix would be great.
@HeneryH,
It does not matter to PiGateway how you generate the HTTP request so long as it is valid.
HeneryH
  • Full Member
« Reply #10 on: April 26, 2020, 07:14:16 PM »
@HeneryH,
Is there any reference anywhere as to what 'valid' is?
sparky
  • Sr. Member
« Reply #11 on: April 26, 2020, 07:37:38 PM »
No response in terminal when sending UPTIME.. or SYSFREQ..
When doing a restart the only thing I get other than normal node data is;
11:53:09.563 : SERVERTIME OFFSET: 3161ms
« Reply #12 on: April 26, 2020, 08:13:44 PM »
Not 100% sure what you're asking.
I blogged about this feature in the 9.0 release.
Here is a simple GET request with a query string:  https://raspberrypi/httpendpoint/?id=1234&MOTION&F=77.77
You could simply type this in the browser and it will post the 2 metrics to node 1234.
If you need to generate a HTTP request from some other place, then there are MANY methods to do so.
« Reply #13 on: April 26, 2020, 08:18:29 PM »
Did you verify you have the correct PiGateway sketch running on your RF gateway?
Look starting at line 191 in the link above. It prints out a few commands back to the gateway.
sparky
  • Sr. Member
« Reply #14 on: April 26, 2020, 08:39:21 PM »
Yes, that's the sketch I'm using..
Results from SEND & SIMULATE UPTIME msg;
08:15:47.823 : /dev/ttyUSB0(simulated)>:[1]UPTIME
08:15:46.563 : GARAGE POLL STATUS: CLOSED
08:15:40.458 : /dev/ttyUSB0>:[6] CM:3 SS:-28
08:15:24.328 : /dev/ttyUSB0>:DEBUG:handleSerialData:1:UPTIME
But I never get a response.
« Last Edit: April 27, 2020, 08:19:17 AM by sparky »
