Node red and Pi Gateway??
Started by Joshua, November 14, 2017, 10:27:55 PM
Joshua
Hello folks,
Does Node Red work in conjunction with Pi Gateway? I'm reading up on the Pi Gateway with components to be delivered this week. I've seen references to Node Red reading traffic. Does this require customization? How is this achieved? I'm just looking for Node Red to read the data and not transmit to the Moteino.
Thanks for you time and consideration.
I have personally not integrated anything for NodeRed on the PiGateway software.
NodeRed is a software layer, and I believe it's quite hardware agnostic. The same is true for PiGateway - it just requires a serial port for communication to the network of devices, which are identified by a numeric ID.
I'm not really clear how you plan to use it though, maybe you can detail on that?
