I'm not worried about the chat part. That is in the guide to help you get past intalling the socket stack correctly. Looks like that works OK?
If so then you must check that your serial port where the Moteino was connected matched what you have in gateway.js. Can you verify that?
Never mind, i got it working now. I feel so stupid
The encrypt key for the base and garagemote where not the same. My bad
thisIsEncryptKey and sampleEncryptKey almost the same
So all is working fine now. Thanks for your help felix
