Keypad input to trigger something
Started by HeneryH, March 23, 2016, 02:17:35 PM
HeneryH
Any ideas on the best way to take this door keypad system as a trigger input into the Gateway?  I'd like to do various things like turn lights on and trigger the security DVR system.  The keypad is 12vdc so I basically have a 12vdc and NO Gnd output that I need to trigger the Gateway.
  <-- Oops, image not showing.  Why do I always have such a hard time with Google Photos.  They are usually so easy with everything.
Thanks for any ideas.
From the schematic it looks like this is a 12V active low interface. Ie you get your GND when the outputs are asserted.
Should be pretty straight forward to get these hooked up to digital pins through some optoisolators.
