Software support => Pi Gateway => Topic started by: Sergegsx on December 04, 2015, 08:04:59 AM
Title: Improving ACK in sketch PiGateway.ino vs Gateway.ino
Post by: Sergegsx on December 04, 2015, 08:04:59 AM
I have been trying to get full reliability when requesting ACK from a Node to the Gateway. What I have found out is that in Gateway.ino I can get a very high reliability whilst in the PiGateway.ino it was sometimes near none ACK received.
I have noticed that these two sketchs differ in the following:
Gateway.ino   https://github.com/LowPowerLab/RFM69/blob/master/Examples/Gateway/Gateway.ino
  //process any serial input
  if (Serial.available() > 0)
    char input = Serial.read();
etc...
PiGateway.ino
  inputLen = readSerialLine(input);
  inputstr = String(input);
  inputstr.toUpperCase();
  if (inputLen > 0)
etc...
by modifying the PiGateway.ino to check if there is Serial data available, the PiGateway will now work very good and get around 96% of ACK with an ok.
  if (Serial.available()>0){
  if (inputLen > 0)
etc...
Anyone has noticed this? Any reason nobody else has reported it (I think)?
Title: Re: Improving ACK in sketch PiGateway.ino vs Gateway.ino
Post by: Jferns on December 04, 2015, 11:52:06 PM
I had the same issue with Acks in PiGateway.ino. With changes similar to what you have listed I get Acks from gateway to nodes correctly.
readSerialLine()  perhaps takes a longer time to respond than Serial.available().
Post by: Sergegsx on December 05, 2015, 08:22:37 AM
I have also noticed that ACK might be working 100% at some times, and then few hours later, same code, same hardware, all running continuously, the ACK success drops a lot !
Any idea why?
Post by: TomWS on December 05, 2015, 08:43:38 AM
Quote from: Sergegsx on December 05, 2015, 08:22:37 AM
Any idea why?
for a node to receive an ACK if using sendWithRetry(), the ACK must be sent within the time allotted to the retry check, which, I believe, defaults to 40mS.  If you also use the default of 3 retries, then you might receive the ACK from the first transmission within 120mS.  This timing might be too tight with a Linux based Gateway, especially if its busy doing some other scheduled task.
In general, a receiving node (gateway or otherwise) should respond with an ACK before doing anything with the received data.
Post by: Sergegsx on December 05, 2015, 08:49:28 AM
Thanks Tom.
The strange thing is that I am running the PiGateway.ino code as in Felix github. As far as the python code reading through serial, I dont think it should affect it. When the PiGateway.ino receives a message from one of the nodes, it will send the ACK back without there being anything that should block it.
This is an extract of the PiGateway.ino. There is nothing blocking once a message is received apart of CheckForWirelessHEX
if (radio.receiveDone())
    int rssi = radio.RSSI;
    DEBUG('[');DEBUG(radio.SENDERID);DEBUG("] ");
    if (radio.DATALEN > 0)
        DEBUG((char)radio.DATA[i]);
      DEBUG("   [RSSI:");DEBUG(rssi);DEBUG("]");
    CheckForWirelessHEX(radio, flash, false); //non verbose DEBUG
    if (radio.ACKRequested())
      radio.sendACK();
      DEBUG("[ACK-sent]");
    DEBUGln();
    Blink(LED,3);
So although I totally understand the ACK time variable, I dont understand why my nodes dont get *ACK ok* all of the times, and moreover, sometimes there is a good period where I get many "ok" and sometimes there are bad periods with mainly "nothing..."
also this code is as in original, so I guess noone else is having this problem?
edit...
in terms of one of the nodes. There is also nothing blocking communication. This is the code extract:
// *********************** SEND MSG VIA RFM69 ***********************************************
byte buffLen=strlen(payload);
delay(5);
if (radio.sendWithRetry(GATEWAYID, payload, buffLen)) {
        Serial.print(" ok!");
        success++;
      else Serial.print(" nothing...");
  Serial.println();
// ************************ SEND MSG VIA RFM69 **********************************************
Post by: TomWS on December 05, 2015, 10:11:31 AM
I suggest you change the code to:
// UPDATE: Forgot to save before calling sendACK() - this is IMPORTANT!
    datalen = radio.DATALEN;
    if (datalen)
      memcpy(rx_buf,(const void *)radio.DATA,datalen);  // save data from device
    sender  = radio.SENDERID;
    target  = radio.TARGETID;
    rssi    = radio.RSSI;
    ackReq  = radio.ACKRequested();
      radio.sendACK();
    CheckForWirelessHEX(radio, flash, false); //non verbose DEBUG  TWS: Is this really needed in a Gateway Node???
    DEBUGln();
    Blink(LED,3);
You will have far more success...
Post by: Sergegsx on December 05, 2015, 10:19:44 AM
It is a good idea, already testing it.
However, big problem, it seems that after doing the "radio.sendACK();" the information received by radio is lost and cant be accessed by radio.SENDERID or radio.SENDERID or radio.DATALEN
Any thoughts?
Thanks Tom
Post by: TomWS on December 05, 2015, 10:21:59 AM
Quote from: Sergegsx on December 05, 2015, 10:19:44 AM
Any thoughts?
Thanks Tom
Yeah, sorry about that.  See my updated post.  I realized as soon as I posted the first answer.
Post by: Sergegsx on December 05, 2015, 10:24:30 AM
just to get it right, what datatype for the new variables? and the rx_buf?
i have tried this but rx_buf gives error
    uint8_t ackReq  = radio.ACKRequested();
    char* rx_buf;
    uint8_t datalen = radio.DATALEN;
    if (datalen)
    uint8_t sender  = radio.SENDERID;
    uint8_t target  = radio.TARGETID;
    uint8_t rssi    = radio.RSSI;
      radio.sendACK();
  //  int rssi = radio.RSSI;
    DEBUGln();
    Blink(LED,3);
thanks !
Post by: TomWS on December 05, 2015, 10:51:57 AM
Quote from: Sergegsx on December 05, 2015, 10:24:30 AM
    char rx_buf[MAX_PACKET_SIZE];
    if (datalen)
      radio.sendACK();
    DEBUGln();
    Blink(LED,3);
thanks !
See correction above.  You need to have space for the data, not an empty pointer to non-existent space...
Post by: Sergegsx on December 05, 2015, 11:11:23 AM
thanks Tom
I have updated and corrected a few things, now it compiles.
- rssi must be an "int" / "int16_t"
- changed the print code to use our new variables instead of "radio."
- changed buffer size to "RF69_MAX_DATA_LEN" as per felix library
    char rx_buf[RF69_MAX_DATA_LEN];
    if (datalen)
      radio.sendACK();
    DEBUG('[');DEBUG(sender);DEBUG("] ");
    if (datalen > 0)
      for (byte i = 0; i < datalen; i++)
        DEBUG((char)rx_buf[i]);
    DEBUGln();
    Blink(LED,3);
I have added some counters to one of my nodes to keep track of how many ACK are lost and give me a %.
Lets see if we have improved!
After only 15 messages. I get 50% success. So far it did not make a difference. :(
I will report back later. thanks
Post by: Sergegsx on December 05, 2015, 11:29:48 AM
Can anyone tell me what are the implications of:
#define ACK_TIME       30 // # of ms to wait for an ack
Can it be increased freely? I cant find the code in the library or sketch that deals with this ack time, so I dont know how it can affect.
btw, I seem to have a "poltergeist" on top of my multi-function printer. As soon as I move the gateway arduino on top of one of its corners I start loosing ACK. If I move it 10cm away from it then 100% ACK!!! (and the printer is plug disconnected)
Isn't it amazing  :o
(see picture of the moment I move the gateway to on top of the printer!)
Post by: Felix on December 05, 2015, 11:37:18 AM
Quote from: Sergegsx on December 05, 2015, 11:29:48 AM
Isn't it amazing  :o
ACK time is somewhat linearly dependent on packet length. Usually ACKs are empty packages so a wait time of 30ms is around maximum. Normally they should be received in under 10ms. This figure is also dependent on bitrate, a very low bitrate will require longer to transmit the same packet, etc.
"Isn't it amazing" - yes very. It has to do with RF and antenna polarization.
Post by: Sergegsx on December 05, 2015, 11:41:04 AM
Thanks Felix. Just to learn a bit more, where is it used the value specified in the sketch? I cant find any reference to it anywhere apart of its definition in PiGateway.ino
I have lost more than a few hours just because the first time using the RFM69 I happened to leave the gateway on top of the printer!! :-[
Post by: Sergegsx on December 06, 2015, 02:35:36 AM
Would you consider 96% of success in getting ACK a good value? I have 3 rfm69hw in the same room and separated 3m and 2m from the gateway.
I am pretty sure all the messages are arriving but ACK is around 96%. Is this acceptable? I was hoping a bit higher value
Post by: joelucid on December 06, 2015, 06:34:03 AM
QuoteWould you consider 96% of success in getting ACK a good value?
I track retransmit rate for my sensors. After running for a couple of months with excellent RSSI the three AC-powered Motes I deploy (these are the only ones that use acks) have a retransmit rate of 1.5%, 1.6% and 1.8%. This is not Tom's implementation, but I also tune transmit power.
If your GW is a raspberry pi before version 2 and you're using 433Mhz that could explain transmit problems. I couldn't get two version 1 Pi's to work well at all as GW's. Version 2 works better but there are still interference issues. Specifically I have a "2 phase" RSSI problem: From the same Mote the GW will see packets sent at the same power at two very different RSSI levels. As an example one node comes in at -61 or -42, but really not much in between. This problem only exists when the GW moteino is hooked up directly to the serial connection of the Pi (not USB, which is too high latency for my purposes).
Probably not your issue - but I like to throw it out from time to time to see if anybody has a solution  :)
Joe
Post by: Sergegsx on December 06, 2015, 06:50:03 AM
I have the GW connected to a Raspberry Pi 1, but via a USB converter. Does this mean something in your experience?
Why do you mention RPi1 and 433 ? I do have that combination but as I say using usb converter.
what do you mean by retransmite rate of 1.6%?
my 96% means that after the default 3 retries done by send command. 96% of the messages get a correct ACK back.
thanks
Post by: joelucid on December 06, 2015, 07:50:17 AM
QuoteI have the GW connected to a Raspberry Pi 1, but via a USB converter.
I have never tried with FTDI adapter but always connect directly to the Pi's UART so this still could be problematic with the pi1.
QuoteWhy do you mention RPi1 and 433 ? I do have that combination but as I say using usb converter.
I mention it because some people here have had these issues with the Pi 1 and as I remember they all had 433mhz. Others (including Felix) never saw problems with the Pi1 and at least Felix probably doesn't use 433mhz.
Quotewhat do you mean by retransmite rate of 1.6%?
Oh that's much worse than mine then. Mine is the number of failed sends (because of missing ack) divided by the number of updates sent (several attempts to send one update counting as 1 update). So if one update fails completely after 3 attempts that would count as 3 failed sends and 1 update or a retransmit rate of 300% for that one update. Missing ack rate would really be a better name for the measure.
If your 96% successful transmits all succeeded on the first attempt (not likely) that would translate into a retransmit rate of 12% in my world. I wouldn't be surprised if it were >20% in your case given that 4% of your updates fail 3x in series. That is definitely a very bad ratio of unsuccessfully sent packets.
If you want to test if its the Pi simply disconnect your GW from the Pi and check if things get better. I think I connected it to a macbook instead back when I debugged these issues.
