Software support => Pi Gateway => Topic started by: hickse on August 02, 2020, 01:34:21 PM
Title: Importing settings and data
Post by: hickse on August 02, 2020, 01:34:21 PM
My Raspberry Pi 3 with Mighty Hat became non-functional after an attempt to restore after saving the SD image and reloading.  I've started from scratch with the newest PiGateway version 9.1.0.
I'd like to load the settings I had in the previous deployment, such as nodes, and historical data if possible. Where are these files and is there any particular procedures that should be followed to update my currently functional system?
Title: Re: Importing settings and data
Post by: Felix on August 03, 2020, 11:01:33 AM
You will need to sudo systemctl stop gateway (once your new install is up and running), and overwrite the settings and database which were on your older installation, on the Pi in these directories:
~/gateway/settings.json5
~/gateway/data/db
Post by: hickse on August 04, 2020, 08:49:00 AM
Thank you Felix, It's nice to have all of my sensor data back!  Thanks for all of you hard work and products.
