Is garage-auto-close working for anyone? It does not seem to be working for me.
I tried also and didn't have any luck. I asked Felix and he thought he had tried it but wasn't positive.
I would like to revisit this event and rebuild it completely.
The problem I have with the current version is that it feels unsafe, the way it's intended to operate.
First, it runs every 30 seconds, but there is a limit of up to 3 run times. So what's the point in running this event all day long, and only actually executing useful code up to 3 times...
Also, the PRs #41 (https://github.com/LowPowerLab/RaspberryPi-Gateway/pull/41) & #42 (https://github.com/LowPowerLab/RaspberryPi-Gateway/pull/42) that ssmall submitted, injects new metric properties back in gateway.js, that nobody else knows about. I don't want to introduce such changes that are some obscure event dependent, in the main app. Programmers call this a code smell and it breaks all kinds of coding rules. I know the contribution is well intended and I realize the gateway.js app is not the easiest piece of code to grasp, so I hope my remarks are not ill received.
I would like to continue the conversation here about how to rewrite this event, and what makes most sense.
I propose something very simple:
- we schedule the event to run 1-3 times between the defined time frame (11-6 or whatever, could be settings in the node).
- when the event runs, check back N minutes (10 in current event code) for unchanged OPEN status. This would take care of erratic CLOSING/OPEN or OPENING/CLOSED cycling.
I think this would be a very simple approach, and eliminate the need to add stray properties to the node's metrics.
