For MultiGraph, select any metric from any node. Resize and select metric color MG.
Started by LukaQ, November 23, 2025, 11:20:49 AM
LukaQ
Hello all,
some might find this useful. I have added option, where in MutiGraph you can select/compare any metric from any node.
This way, I was able to compare outdoor temp (node 5) with another outdoor temp (Tadt from node 4).
I have also added option to resize MultiGraph in Y direction by entering hight in px or in %
I have also added option to select any color or from a palette, for each metric in MultiGraph.
This menu and resize menu are collapsible
what you need to change (overwrite) are gateway.js and index.html
Thanks LukaQ for the contributions, I will check this out and consider adding features like this!
