Main Menu
Events error
Started by sparky, March 17, 2017, 12:58:54 PM
sparky
Felix,
Would the following error have something to do with the new gateway version?
/home/pi/gateway/userMetrics/sprinkler.js:39
  sprinklersOddDays : { label:'Odd days @ 6:30AM', icon:'clock', descr:'Run this sprinkler program on odd days at 6:30AM', nextSchedule:function(node) { return exports.timeoutOffset(6,30); }, scheduledExecute:function(node) { if ((new Date().getDate()%2)==1) sendMessageToNode({nodeId:node._id, action:'PRG 2:300 3:300 1:300 4:300 5:300' /*runs stations 1-5 (300sec each))*/}); } },
TypeError: exports.timeoutOffset is not a function
    at Object.exports.events.sprinklersOddDays.nextSchedule (/home/pi/gateway/userMetrics/sprinkler.js:39:169)
    at schedule (/home/pi/gateway/gateway.js:594:52)
    at /home/pi/gateway/gateway.js:275:17
    at newArguments.(anonymous function) (/home/pi/gateway/node_modules/nedb/lib/executor.js:29:17)
    at Cursor.execFn (/home/pi/gateway/node_modules/nedb/lib/datastore.js:484:12)
    at callback (/home/pi/gateway/node_modules/nedb/lib/cursor.js:126:19)
    at /home/pi/gateway/node_modules/nedb/lib/cursor.js:193:12
    at /home/pi/gateway/node_modules/nedb/lib/datastore.js:329:14
    at Object.async.eachSeries (/home/pi/gateway/node_modules/nedb/node_modules/async/lib/async.js:130:20)
    at /home/pi/gateway/node_modules/nedb/lib/datastore.js:323:11
ssmall
Look in the Metrics.js file and you will find a function called timeoutOffset toward the bottom of metrics.js.  Copy the function from metrics.js to your metrics file and that should take care of the issue.
Quote from: sparky on March 17, 2017, 12:58:54 PM
No.
Can you show the whole sprinkler.js content pls?
sparky
Quote from: ssmall on March 17, 2017, 04:19:28 PM
Perfect!
Very much appreciated
Quote from: Felix on March 17, 2017, 04:24:27 PM
No.
Got it, thanks
sparky,
You should not have to copy the function if you scope your user metrics correctly. I think your user metrics file was probably not in the right format.
sparky
Morning Felix,
Everything was working fine with the sprinkler metric up until I tried to add an event (Run this sprinkler program on odd days at 6:30AM) which then gave me the errors.  It was only after small's response that I added the helper functions.
See attached metric.
Looks good.... i still don't think the core functions need to be duplicated, at least based on something I just tried.
I will keep in mind to try to look into this further.
ssmall
Felix, I have my own sprinkler definition setup in my user metrics.  The only way I could get it to run was to copy the missing functions.  Is there something I can try out so that I can use the functions defined in metrics.js?  I would prefer that to copying them.
sparky
Quote from: ssmall on March 22, 2017, 12:14:15 PM
Do you happen to have a wifi thermostat that you communicate with?  If so, did you try your own metric in the UserMetric folder?
I tried and that will not work without getting the error below, even when the missing functions were copied.
[03-18-17_19:36:46.629] [LOG]   **** RUNNING SCHEDULED EVENT - nodeId:99 event:thermostatPoll...
[03-18-17_19:36:46.636] [ERROR] Event thermostatPoll execution failed: request is not defined
[03-18-17_19:36:46.652] [LOG]   **** SCHEDULING EVENT - nodeId:99 event:thermostatPoll to run in ~30s
I may need to revisit that part of the application. I've only used simple metrics in the user file so far.
