Main Menu
email alerts
Started by Kilo95, February 24, 2016, 08:02:17 PM
Kilo95
I have my sump pump set up to alert if it gets closer than 18cm to the surface. a couple of weeks ago, i updated with the latest Pi Gateway image. since then, it doesn't send the alerts to my SMS. I've double checked the settings.json5 settings 3 or 4 times. nothing looks amiss in gateway.sys.log. any ideas?
Do you see the node in the ui and the metric updating with the message from the sump pump mote?
Is the event enabled?
Are the settings updated? Can you get other SMS messages from other events?
Have your metrics changed in any way?
Kilo95
its the event...I knew I was overlooking something simple. thanks
Event was disabled?
Does it work now?
Kilo95
Yep I'd screwed something up when trying to correct my bmp reading and had reinstalled the pigateway image. Works great now
