Not sure what you mean by "anything to get the internet speed logging within the gateway interface". How fast your internet is? No .. there is no code for that. Maybe you can write something up to poll an API or speedtest.net and report that in a dummy node somehow.
I've got the code to do the speedtest process metrics, so that's no problem. As I understand it, it's easy enough to get an external moteino to send data to the gateway moteino which then passes it to the RasPi serial port to log using the Gateway software I installed.
What I'd like to do is have the raspberry itself be a data generator and send my speedtest data directly to the gateway software. I know I need to setup the metrics that I want to add into the metrics.js file and I think I can work that out based on the examples you've provided. Is it possible to have a py script (or something) connect to the listening gateway app and send the appropriately formatted data directly to the socket listener? Or is the only way to get data into the system is via the moteino that talks to the gateway?
If you have a W/CW then commenting out the #IS_RFM69HW_HCW setting is correct.
Matching settings correctly is crucial to getting a reliable link. Use default settings to start with, match frequency, network, and have separate IDs (1 for gateway), and the HW setting on each node.
Make sure antennas are well soldered, and they do not live in metal boxes.
There's no boxes as yet and yes I'm using the old FRM69W modules on all my moteinos. I've attached a few images to help explain my testing setup. I'm using the breadboard to connect the raspberry to the gateway moteino as I don't have any female-female cables and the test moteino already has the 90 degree header soldered on. Here is what's on the testing bench with the distance between the Gateway and the sonarmote about 80cm.
Transmitter SonarMote// Sample RFM69 sender/node sketch for the SonarMote - Distance tracker
// Can be used for inventory control - ex to measure distance in a multi lane cigarette pack rack
// http://lowpowerlab.com/sonarmote
// Ultrasonic sensor (HC-SR04) connected to D6 (Trig), D7 (Echo), and power enabled through D5
// This sketch sleeps the Moteino and sensor most of the time. It wakes up every few seconds to take
// a distance reading. If it detects an approaching object (car) it increases the sampling rate
// and starts lighting up the LED (from green to yellow to red to blinking red). Once there is no more
// motion the LED is turned off and the cycle is back to a few seconds in between sensor reads.
// Button is connected on D3. Holding the button for a few seconds enters the "red zone adjust" mode (RZA).
// By default the red zone limit is at 25cm (LED turns RED below this and starts blinking faster and faster).
// In RZA, readings are taken for 5 seconds. In this time you have the chance to set a new red zone limit.
// Valid new red zone readings are between the RED__LIMIT_UPPER (default 25cm) and MAX_ADJUST_DISTANCE (cm).
// In RZA mode the BLU Led blinks fast to indicate new red limit distance. It blinks slow if the readings are invalid
// If desired this value could be saved to EEPROM to persist if unit is turned off
// Get the RFM69 at: https://github.com/LowPowerLab/
// Make sure you adjust the settings in the configuration section below !!!
// Copyright Felix Rusu 2016, http://www.LowPowerLab.com/contact
// License
// This program is free software; you can redistribute it
// and/or modify it under the terms of the GNU General
// Public License as published by the Free Software
// Foundation; either version 3 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will
// be useful, but WITHOUT ANY WARRANTY; without even the
// implied warranty of MERCHANTABILITY or FITNESS FOR A
// PARTICULAR PURPOSE. See the GNU General Public
// License for more details.
// Licence can be viewed at
// http://www.gnu.org/licenses/gpl-3.0.txt
// Please maintain this license information along with authorship
// and copyright notices in any redistribution of this code
#include <RFM69.h> //get it here: https://www.github.com/lowpowerlab/rfm69
#include <SPI.h> //included with Arduino IDE (www.arduino.cc)
#include <LowPower.h> //get library from: https://github.com/lowpowerlab/lowpower
//writeup here: http://www.rocketscream.com/blog/2011/07/04/lightweight-low-power-arduino-library/
//************ IMPORTANT SETTINGS - YOU MUST CHANGE/CONFIGURE TO FIT YOUR HARDWARE *************
#define NODEID 22 //unique for each node on same network
#define GATEWAYID 1 //node Id of the receiver we are sending data to
#define NETWORKID 200 //the same on all nodes that talk to each other including this node and the gateway
#define FREQUENCY RF69_433MHZ //others: RF69_433MHZ, RF69_868MHZ (this must match the RFM69 freq you have on your Moteino)
// #define IS_RFM69HW_HCW //uncomment only for RFM69HW/HCW! Leave out if you have RFM69W/CW!
#define ENCRYPTKEY "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
#define SENDLOOPS 80 //default:80 //if no message was sent for this many sleep loops/cycles, then force a send
#define READ_SAMPLES 3
#define HISTERESIS 2 //(cm) only send a message when new reading is this many centimeters different
#define DIST_READ_LOOPS 2 //read distance every this many sleeping loops (ie if sleep time is 8s then 2 loops => a read occurs every 16s)
//#define BUZZER_ENABLE //uncomment this line if you have the BUZZER soldered and want the sketch to make sounds
#define SERIAL_EN //uncomment if you want serial debugging output
#define SLEEP_FASTEST SLEEP_15MS
#define SLEEP_FAST SLEEP_250MS
#define SLEEP_SEC SLEEP_1S
#define SLEEP_LONG SLEEP_2S
#define SLEEP_LONGER SLEEP_4S
#define SLEEP_LONGEST SLEEP_8S
period_t sleepTime = SLEEP_LONG; //period_t is an enum type defined in the LowPower library (LowPower.h)
#ifdef __AVR_ATmega1284P__
#define LED 15 // Moteino MEGAs have LEDs on D15
#define FLASH_SS 23
#else
#define LED 9 // Moteinos have LEDs on D9
#define FLASH_SS 8
#endif
#define TRIG 6 // digital pin wired to TRIG pin of ultrasonic sensor
#define ECHO 7 // digital pin wired to ECHO pin of ultrasonic sensor
#define SENSOR_EN 5 // digital pin that enables power to ultrasonic sensor
#define BUZZER 4 // digital pin that is connected to onboard buzzer
#define MAX_DISTANCE 150 // maximum valid distance
#define MIN_DISTANCE 1.5 // minimum valid distance
#define MAX_ADJUST_DISTANCE (MAX_DISTANCE-GRN_LIMIT_UPPER) //this is the amount by which the RED_LIMIT_UPPER can by increased
#ifdef SERIAL_EN
#define SERIAL_BAUD 115200
#define DEBUG(input) {Serial.print(input);}
#define DEBUGln(input) {Serial.println(input);}
#define SERIALFLUSH() {Serial.flush();}
#else
#define DEBUG(input);
#define DEBUGln(input);
#define SERIALFLUSH();
#endif
#define BATT_MONITOR A7 // Sense VBAT_COND signal (when powered externally should read ~3.25v/3.3v (1000-1023), when external power is cutoff it should start reading around 2.85v/3.3v * 1023 ~= 883 (ratio given by 10k+4.7K divider from VBAT_COND = 1.47 multiplier)
#define BATT_READ_LOOPS SENDLOOPS // read and report battery voltage every this many sleep cycles (ex 30cycles * 8sec sleep = 240sec/4min). For 450 cycles you would get ~1 hour intervals between readings
#define BATT_FORMULA(reading) reading * 0.00322 * 1.475 // >>> fine tune this parameter to match your voltage when fully charged
#define BATT_LOW 3.55
byte sendLen;
byte sendLoops=0;
byte distReadLoops=0;
byte battReadLoops=0;
float distance=0;
float prevDistance=0;
float batteryVolts = 5;
char buff[50]; //this is just an empty string used as a buffer to place the payload for the radio
char* BATstr="BAT:5.00v"; //longest battery voltage reading message = 9chars
char* DISTstr="99999.99cm"; //longest distance reading message = 5chars
float readDistance(byte samples=1); //take 1 samples by default
RFM69 radio;
void setup() {
#ifdef SERIAL_EN
Serial.begin(SERIAL_BAUD); // Open serial monitor at 115200 baud to see ping results.
#endif
#ifdef IS_RFM69HW_HCW
radio.setHighPower(); //must include this only for RFM69HW/HCW!
#endif
radio.encrypt(ENCRYPTKEY);
//sprintf(buff, "\nTransmitting at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
sprintf(buff, "\nTransmitting at %d Mhz, id:%d nid:%d gid:%d", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915, NODEID, NETWORKID, GATEWAYID);
DEBUG(buff);
for (byte i=0;i<strlen(ENCRYPTKEY);i++) DEBUG(ENCRYPTKEY[i]);
DEBUGln();
radio.sleep();
pinMode(TRIG, OUTPUT);
pinMode(ECHO, INPUT);
pinMode(SENSOR_EN, OUTPUT);
digitalWrite(SENSOR_EN, LOW);
#ifdef BUZZER_ENABLE
pinMode(BUZZER, OUTPUT);
buzzer(50,2,100);
#endif
radio.sendWithRetry(GATEWAYID, "START", 5);
SERIALFLUSH();
readDistance(); //first reading seems to always be low
readBattery();
void loop() {
if (battReadLoops--<=0) //only read battery every BATT_READ_LOOPS cycles
readBattery();
battReadLoops = BATT_READ_LOOPS-1;
if (distReadLoops--<=0)
distance = readDistance(READ_SAMPLES);
distReadLoops = DIST_READ_LOOPS-1;
float diff = distance - prevDistance;
if ((diff > HISTERESIS || diff < -HISTERESIS) || (sendLoops--<=0)) //only send a new message if the distance has changed more than the HISTERESIS or if sendloops has expired
if (distance > MAX_DISTANCE || distance < MIN_DISTANCE)
DISTstr = "0"; // zero, out of range
else dtostrf(distance,3,2, DISTstr);
if (diff > HISTERESIS || diff < -HISTERESIS)
sprintf(buff, "%scm BAT:%s", DISTstr, BATstr); //send both distance and battery readings
else
sprintf(buff, "BAT:%s", BATstr); //distance has not changed significantly so only send last battery reading
sendLen = strlen(buff);
digitalWrite(LED, HIGH);
DEBUG(buff);
if (radio.sendWithRetry(GATEWAYID, buff, sendLen))
prevDistance = distance;
DEBUG(" - ACK:OK! RSSI:");
DEBUGln(radio.RSSI);
else DEBUGln(" - ACK:NOK...");
digitalWrite(LED, LOW);
sendLoops = SENDLOOPS-1; //reset send loop counter
radio.sleep();
SERIALFLUSH();
LowPower.powerDown(sleepTime, ADC_OFF, BOD_OFF); //put microcontroller to sleep to save battery life
float readDistance(byte samples)
if (samples == 0) samples = 1;
if (samples > 10) samples = 10;
digitalWrite(SENSOR_EN, HIGH);
//need about 60-75ms after power up before HC-SR04 will be usable, so just sleep in the meantime
LowPower.powerDown(SLEEP_60MS, ADC_OFF, BOD_OFF);
LowPower.powerDown(SLEEP_15MS, ADC_OFF, BOD_OFF);
PING();
unsigned long duration = 0;
for (byte i=0; i<samples; i++)
duration += PING();
if (samples > 1) LowPower.powerDown(SLEEP_15MS, ADC_OFF, BOD_OFF);
return microsecondsToCentimeters(duration / samples);
long PING()
digitalWrite(TRIG, LOW);
delayMicroseconds(2);
digitalWrite(TRIG, HIGH);
delayMicroseconds(5);
return pulseIn(ECHO, HIGH);
void readBattery()
unsigned int readings=0;
for (byte i=0; i<5; i++) //take several samples, and average
readings+=analogRead(BATT_MONITOR);
batteryVolts = BATT_FORMULA(readings / 5.0);
dtostrf(batteryVolts,3,2, BATstr); //update the BATStr which gets sent every BATT_CYCLES or along with the MOTION message
if (batteryVolts <= BATT_LOW) BATstr = "LOW";
float microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74.0 / 2.0f;
float microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return (float)microseconds / 29.0f / 2.0f;
void buzzer(byte soundTime, byte repeats, byte repeatsDelay)
for (byte i=0;i<=repeats;i++)
tone(BUZZER, 4500); //4500hz makes a nice audible sound from a 3.3v Moteino digital pin
delay(soundTime);
noTone(BUZZER);
if (repeats>0) delay(repeatsDelay);
#endif
void Blink(byte pin)
pinMode(pin, OUTPUT);
digitalWrite(pin, HIGH);
delay(2);
digitalWrite(pin, LOW);
Gateway Moteino attached to RasPi
// Moteino gateway/base sketch that works with Moteinos equipped with RFM69W/RFM69HW/RFM69CW/RFM69HCW
// This is a basic gateway sketch that receives packets from end node Moteinos, formats them as ASCII strings
// with the end node [ID] and passes them to Pi/host computer via serial port
// (ex: "messageFromNode" from node 123 gets passed to serial as "[123] messageFromNode")
// It also listens to serial messages that should be sent to listening end nodes
// (ex: "123:messageToNode" sends "messageToNode" to node 123)
// Make sure to adjust the settings to match your transceiver settings (frequency, HW etc).
// License
#include <RFM69.h> //get it here: https://github.com/lowpowerlab/rfm69
#include <RFM69_ATC.h> //get it here: https://github.com/lowpowerlab/RFM69
#include <RFM69_OTA.h> //get it here: https://github.com/lowpowerlab/RFM69
#include <SPIFlash.h> //get it here: https://github.com/lowpowerlab/spiflash
//**** IMPORTANT RADIO SETTINGS - YOU MUST CHANGE/CONFIGURE TO MATCH YOUR HARDWARE TRANSCEIVER CONFIGURATION! ****
#define NODEID 1 //the ID of this node
#define NETWORKID 200 //the network ID of all nodes this node listens/talks to
#define FREQUENCY RF69_433MHZ //Match this with the version of your Moteino! (others: RF69_433MHZ, RF69_868MHZ)
#define ENCRYPTKEY "sampleEncryptKey" //identical 16 characters/bytes on all nodes, not more not less!
#define ACK_TIME 50 // # of ms to wait for an ack packet
#define ENABLE_ATC //comment out this line to disable AUTO TRANSMISSION CONTROL
#define ATC_RSSI -75 //target RSSI for RFM69_ATC (recommended > -80)
// Serial baud rate must match your Pi/host computer serial port baud rate!
#define SERIAL_EN //comment out if you don't want any serial verbose output
#define SERIAL_BAUD 19200
#define FLASH_SS 23 // and FLASH SS on D23
#else
#define FLASH_SS 8 // and FLASH SS on D8
#endif
#ifdef SERIAL_EN
#define DEBUG(input) {Serial.print(input); delay(1);}
#else
#endif
#ifdef ENABLE_ATC
RFM69_ATC radio;
#else
RFM69 radio;
#endif
SPIFlash flash(FLASH_SS, 0xEF30); //EF30 for 4mbit Windbond FlashMEM chip
void setup() {
delay(10);
#endif
#ifdef ENABLE_ATC
#endif
char buff[50];
sprintf(buff, "\nTransmitting at %d Mhz...", radio.getFrequency()/1000000);
DEBUGln(buff);
if (flash.initialize())
DEBUGln("SPI Flash Init OK!");
else
DEBUGln("SPI FlashMEM not found (is chip onboard?)");
byte ackCount=0;
byte inputLen=0;
char input[64];
byte buff[61];
String inputstr;
void loop() {
inputLen = readSerialLine(input);
inputstr = String(input);
inputstr.toUpperCase();
if (inputLen > 0)
if (inputstr.equals("KEY?"))
DEBUG("ENCRYPTKEY:");
DEBUG(ENCRYPTKEY);
byte targetId = inputstr.toInt(); //extract ID if any
byte colonIndex = inputstr.indexOf(":"); //find position of first colon
if (targetId > 0)
inputstr = inputstr.substring(colonIndex+1); //trim "ID:" if any
if (targetId > 0 && targetId != NODEID && targetId != RF69_BROADCAST_ADDR && colonIndex>0 && colonIndex<4 && inputstr.length()>0)
inputstr.getBytes(buff, 61);
//DEBUGln((char*)buff);
//DEBUGln(targetId);
//DEBUGln(colonIndex);
if (radio.sendWithRetry(targetId, buff, inputstr.length()))
DEBUGln("ACK:OK");
else
DEBUGln("ACK:NOK");
if (radio.receiveDone())
int rssi = radio.RSSI;
DEBUG('[');DEBUG(radio.SENDERID);DEBUG("] ");
if (radio.DATALEN > 0)
DEBUG((char)radio.DATA[i]);
DEBUG(" [RSSI:");DEBUG(rssi);DEBUG("]");
CheckForWirelessHEX(radio, flash, false); //non verbose DEBUG
if (radio.ACKRequested())
radio.sendACK();
DEBUG("[ACK-sent]");
DEBUGln();
Blink(LED,3);
pinMode(PIN, OUTPUT);
digitalWrite(PIN,HIGH);
delay(DELAY_MS);
digitalWrite(PIN,LOW);
Actual TestBench showing moteinos. That's a deck of playing cards in front of the Sonarmote that I'll move a bit to see how the responses are.
Serial monitor of
SonarMote showing lots of NOK which I can't work out why so many NOK. Do both sides need ATC? The test script only has the gateway with ATC so I tried adding ATC to both sides, but it didn't seem to help.
I tried to review the serial port with "sudo minicom -b 19200 -o -D /dev/ttyAMA0" and I can see that the gateway moteino get all the messages and I see the Gateway message saying "ACK sent".
The issue seems to be just the SonarMote moteino not seeing the ACK being sent from the gateway.
I'm pretty sure I must be doing something stupid or missing something obvious. I'm going to redo both moteinos and load the Struct_receive & Struct_send and see what results I get with those scripts on their own.
