Main Menu
Dashboard node
Started by tunkmountainman, May 17, 2019, 03:28:48 PM
tunkmountainman
      Does anyone know where in the index.html file is the section for adding an additional node Type?
Stock node types are defined in metrics.js
I recommend you add your custom node and metrics in the userMetrics folder, following the example there.
When you make edits to metrics you must restart the Gateway software for changes to take effect.
